Moog 4 pole transistor ladder VCF
Page 1 of 1 [9 Posts]
Wobble
PostPosted: Thu Feb 16, 2017 7:04 am    Post subject: Moog 4 pole transistor ladder VCF
Subject description: Feature request
Is there already a module that imitates the classic Moog lowpass?
If not, I would like to make a feature request for one. I found this simple implementation (its GPL):
https://github.com/ddiakopoulos/MoogLadders/blob/master/src/HuovilainenModel.h
I found it from here: https://github.com/ddiakopoulos/MoogLadders
Audio files: 243
G2 patch files: 319
PostPosted: Thu Feb 16, 2017 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Will have a look when I find some time, thanks :-)
Audio files: 243
G2 patch files: 319
PostPosted: Fri Feb 17, 2017 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's actually quite a nice filter .. a bit rough here and there so had to tame it a bit to keep it from exploding ... will attach a recorded sample .. with a tad of reverb added.
But its not a cheap filter - CPU wise. Oh and it has some aliasing when it self oscillates ... maybe I'll change things a bit more .. dunno .. I like it rough too.
moogsample.mp3
sample of Wren proto moog style filter
 Filename:  moogsample.mp3
 Filesize:  451.02 KB
 Downloaded:  922 Time(s)
Wobble
PostPosted: Fri Feb 17, 2017 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, that a shame about the CPU, cause I would like to use many of them.
Your sample sounds good.
Looking forward to trying it. Smile
Wobble
PostPosted: Sun Feb 26, 2017 9:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
From my initial experience playing around with the MoogFilter, I like it.
Is it a 12DB/Octave?
And great release, nice fixes and new modules to play around with. Smile
Audio files: 243
G2 patch files: 319
PostPosted: Mon Feb 27, 2017 2:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought 24 dB/Oct as its a four pole low pass.
Wobble
PostPosted: Mon Feb 27, 2017 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the tooltip say 12 DB.
Audio files: 243
G2 patch files: 319
PostPosted: Mon Feb 27, 2017 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
That needs a change then Laughing
Audio files: 243
G2 patch files: 319
PostPosted: Mon Feb 27, 2017 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Changed a handful of other wrong ones as well.
