Wan
Joined: Mar 31, 2004 Posts: 255 Location: Netherlands, Ugchelen
G2 patch files: 46
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Fri Jun 10, 2005 8:35 am Post subject:
I don't know why it squelches either, but I love the sounds. Changing the divider settings is quite interesting. This is indeed surprising. I would have never thought of trying something like this.  _________________ --Howard
my music and other stuff |
Axiom
G2 patch files: 28
Audio files: 107
Axiom
G2 patch files: 28
Posted: Fri Jun 10, 2005 12:56 pm Post subject:
Cool I'd play much with those converters. Nice ideas can be developed with those.
Luca _________________
Posted: Fri Jun 10, 2005 12:58 pm Post subject:
Wan,
By doing the bit-selection the way you do inbetween the ADC and DAC, you're doubling certain bits, while throwing away others.
I made a simple graph using a spreadsheet, that is setup like most software compressors are- input on X-axis, output on Y-axis. To simplify, I only used 5 bits of adc/dac, but it easily makes the point here.
series 1 - linear (adc -> dac direct 1:1 connection)
series 2 - highest bit is used in place of highest & second highest bit.
series 3 - middle bit (bit 3 here) is used in place of bit 2 also.
series 4 - bit 5 (highest bit) replaces bit 5 and 4, bit 3 replaces bit 3 and 2 (somewhat combined series 2 & 3 ).
I use this method to create various look-up tables (that are larger than the 16 length (4 bit) sequencer/table that is available as a module. But I like the oddity you've come up with.
As for squeltching, it would depend on the divider/bit selection, and the frequency content of the input signal. In essence, (refer to the picture), a repeating wave (ie-frequency) would be jumbled up, in a repeating way. So in essence, you are moving the energy in certain frequencies to other frequencies. It'd probably be a good exercise to look at the "RAW" waveform and "DIST" waveforms through a FFT analyzer on your PC.
| example graph of "squeltch without filter". |
45.18 KB |
| Viewed: |
9065 Time(s) |
Wan
G2 patch files: 46
Posted: Sat Jun 11, 2005 7:24 am Post subject:
| jksuperstar wrote: |
As for squeltching, it would depend on the divider/bit selection, and the frequency content of the input signal. In essence, (refer to the picture), a repeating wave (ie-frequency) would be jumbled up, in a repeating way. So in essence, you are moving the energy in certain frequencies to other frequencies. It'd probably be a good exercise to look at the "RAW" waveform and "DIST" waveforms through a FFT analyzer on your PC. |
Thanks for this explanation, it is still a bit over my head, but the transfer of energy from frequencies to other frequencies is something that makes it a bit easier to grasp. I shall try to take a look at FFT analyses. _________________ Grtz Wan |
Wan
G2 patch files: 46
Wan
G2 patch files: 46
Posted: Sat Jun 11, 2005 3:04 pm Post subject:
| Axiom wrote: | Cool I'd play much with those converters. Nice ideas can be developed with those.
Luca |
Sure, yours and Howards ideas are nice and promising. There are things happening in the patterns that catch my ear. I am going to delve further in this waveshaping with adda. _________________ Grtz Wan |
Wan
G2 patch files: 46
Axiom
G2 patch files: 28
Posted: Sun Jun 12, 2005 6:29 am Post subject:
lol i can't believe it i'm been working to the same thing this morning I will load your patch soon into my G2.
Audio files: 107
Wan
G2 patch files: 46
Posted: Sun Jun 12, 2005 1:24 pm Post subject:
| mosc wrote: | | These sounds have a renaisance quality to them. Brings to mind a Christmas carole. |
I know the tune, but i never expected this sound relates to it. Now where is that score of jingle bells? _________________ Grtz Wan |
