 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
Audio > Trigger > MIDI
Electromagnetic Wave
G2 patch files: 34
PostPosted: Tue Mar 14, 2017 8:46 am    Post subject: Audio > Trigger > MIDI Reply with quote  Mark this post and the followings unread
Here is a patch to trig MIDI stuff from audio. Audio volume can control velocity and/or control change. Could be very usefull to create a groove from a pre recorded melody, with an arpegiator or to record MIDI drum pattern from audio signal.
I added 2 different building block for the trigger and Pitch Tracker part. I have to integrate an autotune block (need to dig in the 'Basic Autotune' patch from moody33) to control the pitch because the Pitch Tracker in the patch is not working very good or Im not a good singer !!
I made another version with a internal recorder for automation in the patch (trigger + #cc automation) but I got difficulty to obtain a linear automation because of the variation in db when I send a signal to the microphone.
2 NoteSend modules. To send the signal to other slots and to record to external gear.... and playback from external gear after.
I added a basic video to show you how it's work.
Assign MIDI channel on parameter pages E1 and E3. Others parameters to adjust are assigned on front pannel too.
In the video 1st I play with the G2 arpegiator running in the same slot as the AudioTriggerMIDI patch.
At 0.40 I use variations assigned to different MIDI channel to trig many sounds.
At 2.40 I show MIDI routing and patch overview on the editor.
At 4.40 I record a melody to the external sequencer. After I send the recorded MIDI to the AudioTriggerMIDI patch. Then I create and record a new groove (MIDI) with the microphone.
Have fun Smile
AudioTrigMIDIv25.pch2
 Filename:  AudioTrigMIDIv25.pch2
 Filesize:  2.11 KB
 Downloaded:  261 Time(s)
