My Andromeda Suddenly Won't Boot
Page 1 of 1 [9 Posts]
badcatblackcat
PostPosted: Thu Jul 20, 2017 6:13 am    Post subject: My Andromeda Suddenly Won't Boot Reply with quote  Mark this post and the followings unread
Hi. I've had my Andromeda for four or five years and it's always worked perfectly. All of the sudden, it hangs on the initial screen when I turn it on. Would appreciate any suggestions anyone might have.
Thanks.
particlesintowaves
PostPosted: Tue Jul 25, 2017 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't have any advice but I posted this to the Andromeda Facebook group. It's a bit more active than this forum so hopefully that nets you a response or two.
particlesintowaves
PostPosted: Tue Jul 25, 2017 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I also PMed you, but here's one idea from Facebook:
"Boot up holding soft key 4 or 1. Mine hangs on boot but never had a problem loading with soft keys"
badcatblackcat
PostPosted: Tue Jul 25, 2017 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Alas, I've tried booting the A6 while holding each of the soft buttons to no avail. Just stays on the start screen.
Airlock
Audio files: 37
PostPosted: Tue Jul 25, 2017 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you are trying to avoid taking it to a tech you might try opening her up and reseating every ribbon cable connection you can see, and if you can solder replace the battery while you're in there. This link show which screws to take out:
http://www.harmonycentral.com/forum/forum/Keyboards/acapella-18/315564-
(Huh, a useful Harmony Central thread....)
Good luck!
badcatblackcat
PostPosted: Wed Jul 26, 2017 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I'll give that a try.
adhmzaiusz
PostPosted: Fri Jul 28, 2017 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
unfortunately it is highly likely your main flash is corrupt. If it's not that, it is the CPU. The only way is to reflash a new one and solder it in...
I had to do this myself but the A6 works perfectly now.
There is a big long discussion on the gearslutz forum about this exact problem.
badcatblackcat
PostPosted: Fri Jul 28, 2017 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
After trying everybody's suggestions that were within my powers to no avail, I took my Andromeda to the synth doctor.
sunny pedaal
Audio files: 12
PostPosted: Mon Aug 07, 2017 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
please let us know what happens / how he fixed it.
there are luckily some people specializing in it nowadays, one i know in the netherlands however. maybe a good idea to collect and share some good en dedicated a6 servicemen/ women ?
