today> Muied Lumens Frequencies
Output monitor problem
Page 1 of 1 [2 Posts]
Flareless
PostPosted: Fri Jul 21, 2017 5:32 am    Post subject: Output monitor problem Reply with quote  Mark this post and the followings unread
I'm having a problem with my Yusynth Output Monitor module from Soundtronix. I've got it set up with the Panning Mixer. The Mixer seems to be working fine however there seems to be a problem with the monitor...
First, on output to the headphone potentiometer ("To Headphone Level Pot") the centre pin which indicates GND is getting a voltage over it. Adjusting the headphone pot has no effect on the volume of the headphones when they are connected.
Second, adjusting the bass and treble pots from their centre (12:00) positions makes the audio cut out.
I'm using connectors for all the pots and if I only connect up the inputs from the Panning Mixer and the output to the jacks the Master volume control seems to work fine.
I've double checked the parts on the PCB, checked for bad solder joints or bridges, etc... and can't seem to find anything wrong.
I've actually built two of these modules (Mixer & Output sections) at the same time and they're both experiencing the same problems.
Any suggestions?
Rich
Lower West Side Studio
Fizzbin on SoundCloud
Flareless
PostPosted: Sat Jul 22, 2017 8:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is a problem with the Output Monitor module.
There is a missing Ground (Earth) connection on the board at the U1 TL074 pin 3 or 5.
It can be remedied by connecting one of these pins to Ground. I used the centre connection of the 3 wire connection to the Master Volume pot.
(I posted this in the Soundtronix erratum thread as well)
Rich
