Extreme level peak from SqrOsc oscillator
Page 1 of 1 [10 Posts]
ullyssen
PostPosted: Fri Sep 22, 2017 4:57 am    Post subject: Extreme level peak from SqrOsc oscillator Reply with quote  Mark this post and the followings unread
Hi!
I need some strange artifact to be removed from ChucK output.
I created the following code: simple function to control square oscillator:
Code:
fun void sqrG(int tone, int time, int silence)
    SqrOsc o => ADSR e => dac;
    tone => o.freq;
    e.set(0::samp,2::samp,0.5,1::samp);
    e.keyOn();
    time::ms => now;
    e.keyOff();
    silence::ms => now;
Every time this function is executed, resulting square signal contains extreme level peak right at the beginning, as shown on this screenshot from Audition editor:
Interesting is that all other oscillator types (SinOsc, TriOsc, SawOsc) don't produce this artifact.
gabbagabi
PostPosted: Fri Sep 22, 2017 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
hi,
what ur using to measure?
may a soundcard oszilloskope?
if so soundcards often have caps on there inputs that could provoke this behaviour on square waves.
ullyssen
PostPosted: Fri Sep 22, 2017 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
g.gabba wrote:
hi,
No, output was directly recorded to WAV file and analysed in Audtion CS6 editor.
Audio files: 278
PostPosted: Fri Sep 22, 2017 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
It looks like the anti-aliasing behaves a bit strange directly after initialization ... it might be easiest to apply some startup envelope to mask the effect ...
ullyssen
PostPosted: Fri Sep 22, 2017 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Could you provide me with some code example?
Audio files: 278
PostPosted: Fri Sep 22, 2017 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I'm not able to do so ... but I could interpret your image Laughing
Maybe Antimon can come up with something? (when he is not too busy preparing for two shows to run ...)
ullyssen
PostPosted: Fri Sep 22, 2017 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've changed the code, so
Code:
became
Code:
SqrOsc o => Dyno limiter1 => ADSR e => Dyno limiter2 => dac;
and then I've activated both limiter instances.
Yet this peak still emerges.
PostPosted: Mon Sep 25, 2017 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
What strikes me as strange is that ringing occurs BEFORE a step of the signal as well as AFTER the step.
Shocked
my synth
Audio files: 278
PostPosted: Mon Sep 25, 2017 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Heh, ringing before means that it is not ringing but bandlimiting instead being in effect.
Audio files: 278
PostPosted: Mon Sep 25, 2017 5:17 am    Post subject: Reply with quote  Mark this post and the followings unread
You can think of it being a square wave approximated by sines.
