and yet another uncertainty
Page 1 of 1 [9 Posts]
Audio files: 116
G2 patch files: 317
PostPosted: Tue Jun 14, 2005 7:29 am    Post subject: and yet another uncertainty Reply with quote  Mark this post and the followings unread
This one is modeled after the Wiard Model 1210 "Noise Ring" Data Resonator
It definitely does "something", but I don't sem to have gotten it quite right - there seem to be not too many "different values" in the loop, but this might be inherent in the design.
When I make it do the clock sweeps (sending the n^2 and/or n+1 outputs directly to the speakers - watch the volume !!) it seems to sound more or less alike the samples on the page referenced above.
Any improvements appreciated !
Jan.
noise ring.pch2
Controllable random modeled after Wiard's noise ring
 Filename:  noise ring.pch2
 Filesize:  2.01 KB
 Downloaded:  977 Time(s)
PostPosted: Tue Jun 14, 2005 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh Jan! what a nice treat Smile
this patch works at 75% on my 500mhz powerbook (running the G2 demo).
Its nice to hear a Blue Hell patch after such a long time Smile)
Do you use a Wiard system?
ACHTUNG!
Audio files: 116
G2 patch files: 317
PostPosted: Tue Jun 14, 2005 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
No I'm not using or having such a system, but I'm pretty much tied to my chair still after getting home from the US with a nasty bacterial infection on my leg and as a result of that I was just browsing around a bit and ended up on the Wiard site where I saw this module.
This module seemed to be an interesting aproach to find a new way through the order and chaos fields, new to me that is. And it does do some interesting things, but somehow I have the feeling that it should be possible to get more out of this circuit.
Analogue wise I only have a neglected Elektor system.
Jan.
PostPosted: Tue Jun 14, 2005 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I bought a Wiard Wogglebug (source of uncertainty) a year ago or so. Uncertain it certainly is! I can never seem to ever get it to repeat a setting- which is quite frustrating because its quite a one trick pony as a sound source alone.
If I had the entire system then that would be much better- but at over £400 per module Shocked - that seems unlikely.
I bought it because it was the most unique sounding thing I'd ever heard
ACHTUNG!
Audio files: 107
PostPosted: Tue Jun 14, 2005 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is truly wonderful. It's very interesting. There is just the right mix of repetition and unpredictability. Very Happy
Audio files: 107
PostPosted: Tue Jun 14, 2005 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I took your patch, added some controls to make it interactive, put in a tiny bit of processing, and made it polyphonic so it'll work with the keyboard.
noise-ring-a.pch2
An extension of Jan Punter's another source of uncertainty patch. This is designed for interactive playing with a Keyboard G2, but it will work on an engine. Variations are left up to you...
 Filename:  noise-ring-a.pch2
 Filesize:  2.54 KB
 Downloaded:  1095 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Wed Jun 15, 2005 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Reminds me a bit on some Buchla things, Subotnik I guess, this way. Nice mod.
Jan.
PostPosted: Wed Jun 15, 2005 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
mosc, any chance you could send it again without the module that's stopping it load in the demo version (reverb?)
Tom
PS I suppose I could download the editor and do it myself, but that seems a bit of a waste of time- as i'd have to install it, then uninstall it- bit of a faff.
ACHTUNG!
Audio files: 107
PostPosted: Wed Jun 15, 2005 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I took the reverb out.
noise-ring-b.pch2
Special version with reverb removed for Tom for the G2 demo
 Filename:  noise-ring-b.pch2
 Filesize:  2.47 KB
 Downloaded:  1033 Time(s)
Niio1
