 Forum index » Online Music
Can Raspberry Pi be a good instrument? :) A RPi album. ;)
Page 1 of 1 [5 Posts]
yerzmyey
PostPosted: Thu Jan 11, 2018 12:48 pm    Post subject: Can Raspberry Pi be a good instrument? :) A RPi album. ;)
Subject description: the music has been created with Raspberry Pi only. :D
Hi guys.
The Raspberry Pi sounds good too. Wink
https://yerzmyey.bandcamp.com/album/rpi-zwei
_______________________INFOS_____________________________
YERZMYEY - RPi ZWEI
01 RPi Zwei
02 Ursula (part 2)
03 Alien encounter
04 Wake Hime
05 Digital Garbage RPi's Remix
TT: 19:15 min.
This album has been made on Raspberry Pi 2.
Also, it has been recorded entirely & directly from the machine.
The RPi's sound is being generated by the Broadcom BCM2835 chip (for the 1st model of RPi) and by Broadcom BCM2836 chip (in the 2nd model RPi), so it's resolved somewhat like in ZX Spectrum: the sound is being generated by CPU.
They say it works with 11 bit quality. It's not an actual DAC, it is a digital PWM module (gives a 'pulse width modulated' signal) working with frequency around 40MHz and it is low-pass-filtered.
The original Pi sound is warm'n'soft; doesn't remind thousands of razors.
Some people claim RPi isn't good for music.
They are WRONG.
(C) 2018 by YERZ
Original ATARI 2600 song "Digital Garbage" by Bitpusher2600.
WWW sites:
RPi portal: https://www.raspberrypi.org/
Bitpusher2600's portal: http://www.bitpusher2600.net/
YERZMYEY:
http://yerzmyey.i-demo.pl/
https://soundcloud.com/yerzmyey
https://www.youtube.com/user/yerzmyey
________________________________________
http://yerzmyey.i-demo.pl/ - retro-hardware electronic music
http://soytnbg.i-demo.pl/ - Electro-Metal-Industrial
http://republika.pl/spaszaki/ - Casio-Core toy-music Wink
JovianPyx
Audio files: 212
PostPosted: Tue Jan 16, 2018 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice!
I've also worked with RPi technology, I have a few RPi-3, three of them have the Element14-Cirrus audio board which sounds very nice (24 bit stereo up to 192kHz sample rate). I've been able to get as many as 64 voices of polyphony (using ALSA) for several synths with unoptimized C code. I'm currently working on fixing optimization and getting cross core audio communication working properly so that I can have some fairly advanced special effects.
My development environment is just Raspbian, but I do eliminate any service programs I don't need to preserve CPU for the synth.
Time flies like a banana.
corruptio optimi pessima
yerzmyey
PostPosted: Thu Jan 18, 2018 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds most interesting and I would love to hear some outcome, when it's possible.
> I have a few RPi-3
Yes, now I moved to "3" and possibly will stay on it.
That is, if the noise from cooler will not be too big (well, the board is tiny, let's admit - everything is close each-other).
I was actually thinking of exactly the same thing; finally decided to stay with the stock machine this time, to keep it 'minimum' and check out what will come out.
Same here, although I imagine that samples don't take that much of CPU power as soft-synths do.
Max. I used 26 channels at once but I'm pretty sure it could do more (if it would be needed).
All the best!!
Y
JovianPyx
Audio files: 212
PostPosted: Thu Jan 18, 2018 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow - a cooler. I run my Pi3 boards at 1200 MHz constant. I use nothing more than the stick-on heat sinks - and I live in "the desert" of Los Angeles where the temperature can be over 90F (32.22C) which is when I switch on AC. The boards do not have enclosures mainly because they don't fit when the Cirrus board is attached.
I monitor the CPU temperature which usually runs around 50C to 60C with ambient air temperatures close to 21C. This is the case when running one of my synths which I run with 3 isolated cores that burn at 100% when the synth is running. I've never seen it go over 70C (where 85C is absolute maximum).
One of the Pi3 boards is a server (file, web, NTP, NFS, mail, bind, etc.) that runs 24x7 and literally never crashes. Another is a sort of low end workstation that also runs 24x7 and has never crashed. One of the reasons I did this was specifically because of the fan noise of the old server (an Intel P4 HT machine). The Pi3 server actually performs about as well as the old Intel machine.
These machines have been running like this continuously for about 2 years. I never overclock beyond the 1200 MHz limit set by the RPi people.
Have you tried to run it without the cooler?
yerzmyey
PostPosted: Mon Jan 22, 2018 3:41 am    Post subject: Reply with quote  Mark this post and the followings unread
well - so it would seem like I will try.
Especially that it is possible I would have to use the Pi while some concerts.
I used it once before but it was the Pi2 and then I lost my SD card somehow so it's easier to use the Pi3 ready to work than to restore the Pi2.
OK, I will check it out then!
All the best,
Y
