An A4 PCB covered in lunetta circuits
Page 2 of 3 [51 Posts]
mike page
PostPosted: Wed Feb 01, 2017 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
yes that works. However don't use resistors to mix, but diodes like it is done in the baby 10.
out of interest why diodes rather than resistors?
Audio files: 613
PostPosted: Wed Feb 01, 2017 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
If you use resistors you create a voltage divider since all the outputs that aren't 'active' will be low so pretty much 0V.
(even if the outputs of the chip would be floating you'd still have the pots connected to GND) By using diodes you will
block these and only the voltage from the active output will end up on the output.
If you ignore the pots and just connect the outputs together by 100K resistors and the voltage is 12V than you have
1 100K resistor connected to 12V and 9 resistors in parallel (11.1K) conected to 0V. this means that the output voltage
would only be 1.2V. With pots it gets a bit more complicated because all the resistors are variable.
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider
mike page
PostPosted: Wed Feb 01, 2017 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thats what i was thinking. I guess I was just thinking about how audio is passively mixed
mike page
PostPosted: Mon Mar 20, 2017 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a video of it pretty much finished :
https://vimeo.com/209123093
Audio files: 27
PostPosted: Mon Mar 20, 2017 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
interresting! Rolling Eyes
synaesthesia
Audio files: 85
PostPosted: Tue Mar 21, 2017 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Mike, that looks and sounds fantastic! Do you use additional external oscillators or is everything generated on the board?
Audio files: 613
PostPosted: Tue Mar 21, 2017 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
you've done a great job on that, it came out very nice!
mike page
PostPosted: Sat Mar 25, 2017 1:45 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks guys, its mostly 4 of those R2R steppy triangle oscillators. The top board is a bunch of modules designed by peter edwards (casperelectronics), the signal is going through the vcf then into that electro harmonix pedal that is giving the droney reverb noise.
As always as soon as its done an improved design is starting to take shape in my mind...
If I make a video describing all the functions i'll post it here Smile
droffset
PostPosted: Mon May 01, 2017 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
That looks really amazing, congrats. Smile
https://docs.google.com/Doc?docid=0AZIwOP-PR9sSZDlidzgzbV8wY3RjenJqanY&hl=en
Edit: Spelling mistakes.
tjookum
Audio files: 26
PostPosted: Mon May 08, 2017 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rolling Eyes it's been a while..
Really nice work mike page! I think the artistic flowing style really suits the lunetta design. I have tried something along those lines a few years ago but never got around to finishing it. Your machine is looking great, I would love to see a more detailed overview. Here are some things I picked up on my failed attempt, maybe they are of use to you.
I used the cheap uninsulated 4mm banana sockets or eBay special ones with the plastic removed straight through the pcb, with or without soldering. And to keep it nice and cheap I used 16mm pots mounted through the pcb with the pins soldered to pads on the bottom. One of the reasons it never really got off the ground was probably the well known feature creep Laughing . I never seemed to be able to cram enough in and outputs into a reasonable space. I need my 4040 with Blinky lights Very Happy .
Basically it boiled down to cost per connection, 4mm banana's are a way better connector but header pins are just so cheap small and convenient Embarassed
The other thing I was limited by was board space, I was planning on getting them made in china. They generally charge double or more for the bigger sizes. Really good job on the A4 home-made pcb's, any more info on your methods?
Twisted Evil how many header pin lunetta circuits would fit on 1 A4 of copper clad....
Hunter S. Thompson
movies
noise
mike page
PostPosted: Mon May 29, 2017 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Heya. Yeah I find the spraypaint-lasercutter PCB process really effective and fun to do.
I use emachineshop free software to design DXFs
Then spray paint a piece of copper clad board (Ive found bits of A4 for £2 a pop on aliexpress)
Then I use the laser cutter where I work to cut the DXF line into the layer of spray paint (acrylic engrave settings are appropriate)
Next scrub it gently with a green scourer until the gaps in the paint are shiny copper
Then dunk it in ferric chloride, and leave it and agitating it and examining it. Sometimes it helps to give it a quick wash to examine it properly as the ferric chloride is dark. If you hold the board up to a light source you can see clearly where the copper has been removed.
Thats it really, it takes a bit of practice getting the laser settings just right and the amount of spray paint but its not difficult. Its good to get everything setup before you begin somewhere with a tap. Obviously be careful with Ferric Chloride! Wear rubber gloves and goggles and wash your hand thoroughly and regularly whilst working. It will eat through clothing too so best to wear an apron also.
heres a video of it bleeping :
https://www.instagram.com/p/BUCX4xAF0SB/?taken-by=bastlinstruments&hl=en
mike page
PostPosted: Mon May 29, 2017 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
i made a whacker out of a HD for it today too : https://vimeo.com/219427829
PostPosted: Mon May 29, 2017 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I love the use of the HDD. Wild!
dougseidel
PostPosted: Tue May 30, 2017 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Mike: that wacker is fantastic - a great drummer and looks good too.
Thanks for showing and i want to hear more music from it
http://dougseidel/tumblr.com
Audio files: 147
PostPosted: Wed May 31, 2017 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats, Mike. Brilliant. Keep posting those videos.
Top Top
PostPosted: Thu Jun 22, 2017 10:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just noticing this project. Interesting to see someone else planning on magnets for patching!
Would love to hear more in action.
A.M.P. ESOTERIC ELECTRONICS
mike page
PostPosted: Fri Aug 04, 2017 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
my lunetta talking to my tricked out ciat lonbarde gerrasic organ...
GERASSIC from michael page on Vimeo.
[/code]
stolenfat
PostPosted: Sun Aug 06, 2017 2:32 am    Post subject: Reply with quote  Mark this post and the followings unread
very cool!
Is there a filter in there or maybe an adsr?
mike page
PostPosted: Sun Aug 06, 2017 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
the gerassic organ makes sort of plucked tones with clever simple triangles through a simple clever transistor vca. thats going into a resonant filter with the cutoff frequency being sequenced in time with the note trigger data. Oh also the decay of the vca is being poked at to vary the note sustain a bit.
Audio files: 228
G2 patch files: 319
PostPosted: Mon Aug 07, 2017 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice organ!
Audio files: 147
PostPosted: Sat Aug 19, 2017 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup, I like it.
mike page
PostPosted: Sun Oct 29, 2017 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
here is a recording of a nice patch on my lunetta. Im also using an autotune pedal make the notes nicer, a resonant filter and EHX super ego pedal to do the sustained notes:
Audio files: 613
PostPosted: Wed Nov 01, 2017 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
nice one Very Happy
mike page
PostPosted: Thu Feb 08, 2018 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another jam on my lunetta with an autotune pedal and ehx super ego
PostPosted: Fri Feb 09, 2018 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool builds! They look and sound great.
JacobWatters.com
