Getting started building CGS modules [Build Thread]
Page 3 of 3 [72 Posts]
Goto page: Previous 1, 2, 3
haebbmaster
PostPosted: Sun Jan 14, 2018 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hubaswift wrote:
Maybe a general purpose PNP will do.
yes, BC557 or something like that
Make modular synthesizers great again!
Modular Synthesizer DIY blog: http://modular.haebbmaster.de
Hubaswift
PostPosted: Fri Jan 19, 2018 8:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info haebbmaster, hopefully the BC557 will also suitable as a noise transistor for the Serge Noise module.
Here's a picture of some of the pcbs that I've populated so far. There are still a few missing parts since not all of my part orders have arrived.
 Filesize:  1.89 MB
 Viewed:  122 Time(s)
Audio files: 31
PostPosted: Fri Jan 19, 2018 11:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Huba, are those IC sockets dual wipe?
Because they look suspiciously like singlewipe.
Hubaswift
PostPosted: Sat Jan 20, 2018 12:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not very familiar with dualwipe vs singlewipe. What I can say is that some of the sockets are machined (such as the 8 pin one in the pic) and some of the other ones (such as the all black sockets) were salvaged. Is there a drastic importance between single and dualwipe socket usage?
haebbmaster
PostPosted: Sat Jan 20, 2018 12:58 am    Post subject: Reply with quote  Mark this post and the followings unread
It‘s just how good the contacts are. Dual are better than single and machined are best. I don‘t use salvaged parts. Contacts may be bad.
Read this on contacts
http://arcadecontrols.com/BBBB/ic.html
Hubaswift
PostPosted: Sat Jan 20, 2018 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, thanks for the heads up. Tomorrow I'll check the resistance between the pins on the ics, and where the sockets are soldered onto the board to check the continuity. If I notice any problems, I have some machine sockets I can replace the singlewipe ics with.
haebbmaster
PostPosted: Sat Jan 20, 2018 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
The problem is not the problem you have now. The problem will appear in a few years.
Dual wipe have double size contact surfaces than single wipe. So you will have less problems with corrosion.
Hubaswift
PostPosted: Sat Jan 20, 2018 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Dang, I see. I don't know if I have enough machined 14 pin sockets lying around to replace all of them, but I'll replace all the ones I can for now.
Hubaswift
PostPosted: Sat Jan 20, 2018 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I took out one of the socket legs to have a look at it. It looks to me like it may be dualwipe. Here are some photos:
 Filesize:  492.62 KB
 Viewed:  101 Time(s)
 Filesize:  538.31 KB
 Viewed:  112 Time(s)
Hubaswift
PostPosted: Mon Jan 29, 2018 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Julian, the guy who I got to make the panel, is just about done making it! Here are some pictures of the panel he sent me. It looks amazing love
 Filesize:  61.71 KB
 Viewed:  94 Time(s)
 Filesize:  64.25 KB
 Viewed:  100 Time(s)
 Filesize:  71.73 KB
 Viewed:  108 Time(s)
Ayab
PostPosted: Mon Jan 29, 2018 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking good. Have not forgotten transistors, should arrive soon.
Hubaswift
PostPosted: Mon Jan 29, 2018 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
thumleft
other_format
PostPosted: Wed Feb 21, 2018 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for uploading these pcbs, I'm planning on having a go at the DUSG.
Just wondering if there's a reason the 100nF is not connected to -V trace on the left hand part of the circuit (from pin 3 of LF353) while it is connected on the other side? This isn't on the CGS schematic but I think it is connected on the Ken Stone pcb?
 Filesize:  349.59 KB
 Viewed:  92 Time(s)
Hubaswift
PostPosted: Wed Feb 21, 2018 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just another mistake by me... I'll fix it and update the attachment on that post.
Hubaswift
PostPosted: Sat Apr 21, 2018 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I've started mounting all the pots and jacks on the front panel. I've decided to hold off on buying the buchla style knobs for now simply because they are 4x as expensive as your average knob. So, for now I have some different davies clones and mxr knobs on there, and they actually look pretty nice! They'll definitely do for now.
The only things I've left to do are:
-finish mounting all the front panel components
-put a few last parts on the pcbs.
-build a wood case for it
-install the power supply, and pcbs into the case, and wire everything. This will take a while
Building the wood case will probably end up being the biggest holdup. Although I have access to my Fathers carpentry shop, where he has tools such as planers, table saws, chop saw, etc. Since everything is used more for crude construction rather than fine woodworking, most of it is out of calibration in one way or another. The planer's blades need to be sharpened, The fence on the table saw needs to be fixed, and lots of other little things need to be taken care of before I'm comfortable throwing some nice hardwood through the machines.
Here's some pics:
 Filesize:  1.3 MB
 Viewed:  65 Time(s)
 Filesize:  1.62 MB
 Viewed:  78 Time(s)
 Filesize:  1.58 MB
 Viewed:  81 Time(s)
Audio files: 588
PostPosted: Sun Apr 22, 2018 3:51 am    Post subject: Reply with quote  Mark this post and the followings unread
that looks great Razz
do you have a spaceship to go with it ?
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider
Hubaswift
PostPosted: Sun Apr 22, 2018 9:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Phobos! Building a "spaceship" would be such a fun project. Imagine a giant cockpit fitted with modular synths, back-lit front panels, a surround sound sound audio system w/ subs, and instead of a window, a giant curved screen fitted for video synthesis Laughing You wouldn't see me again for a month!
I need to stop daydreaming...
Hubaswift
PostPosted: Fri Jun 22, 2018 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quick update:
No, I haven't forgotten about this project, there have just been a few hiccups. I've been meaning to build a nice enclosure for this project for some time, but part-way in I realized that my planer wasn't planing the wood evenly. One side of the board would be slightly thicker than the other. Just recently I dug up a smaller portable Makita planer and have been using that. It's been working much better. Next, I need to get access to either a router or a router table in order to cut perfect 45-degree angles into the sides of each board. I cut the pieces from the board in such a way so that the grain will perfectly match up all the way around the box. I've attached a picture below portraying what I mean by 45-degree joint.
One other little setback is that I am unimpressed by the quality of the banana jack sockets that I got. If anybody has a recommendation for really solid, good quality (and good lookin') banana jack sockets, I'd love to hear it as I am planning on replacing all of the ones I originally got for the project.
One other thing I'm wondering about is if a switch-mode power supply would cause problems for CGS modules. I'd prefer to use a SMPS in order to obtain a lower profile on the case, but if it would degrade the sound significantly, I don't suppose it'd be worth it. My biggest worry about the SMPS is that I have a spring reverb in the case that would have to be quite close to it.
 Filesize:  7.13 KB
 Viewed:  1309 Time(s)
The Bad Producer
PostPosted: Tue Aug 21, 2018 2:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Bit late to the party! But I use these:
WHITE 530-108-0901-1
RED 530-108-0902-1
BLUE 530-108-0910-1
BLACK 530-108-0903-1
GREEN 530-108-0904-1
GREY 530-108-0913-1
BROWN 530-108-0908-1
VIOLET 530-108-0912-1
YELLOW 530-108-0907-1
ORANGE 530-108-0906-1
Emerson Johnson banana jacks, the best IMO... Note those are Mouser codes, but you can also get them from Farnell (which may be cheaper in some instances)...
Regading SMPS power, I've used a few types with my CGS builds and not had any issues, though I haven't tried next to a spring. FWIW the 73-75 panels from THC use an SMPS too...
Great build BTW!
Hubaswift
PostPosted: Wed Aug 22, 2018 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Emerson jacks are the exact ones I ended up getting. They’re definitely much nicer than the previous ones I had. It’s good to know that a SMPS doesn’t cause any issues synth wise. I really appreciate the info. If worst comes to worst with the spring reverb, I’ll try to find some sort of electrostatic insulation.
The Bad Producer
PostPosted: Thu Aug 23, 2018 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
This one seems pretty good - at least it's used a lot in euro and Buchla modulars (they use the 15V version, you could even use the 15V one and then put linear regulators for 12V on the back end...)
https://www.mouser.co.uk/ProductDetail/MEAN-WELL/PD-2512?qs=V9a8iPeg90zL57YT5CaFMw%3D%3D
It's so cheap it could be worth a punt!
I have used the 15V one for my Buchla, but I must say I've not used the 12V on the CGS / Serge stuff....
Hubaswift
PostPosted: Thu Aug 23, 2018 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the link! I think I used a similar Meanwell 12v SMPS to replace the power supply in a Korg T1 a while ago and I was quite impressed for the price.
