today> Muied Lumens Frequencies
Yusynth Clock Divider External Reset Issue
Page 1 of 1 [5 Posts]
helix_modular
PostPosted: Thu May 03, 2018 12:42 pm    Post subject: Yusynth Clock Divider External Reset Issue
Subject description: Reset on Rising Pulse? [SOLVED]
Hi everybody,
I've developed a stripboard version of this handy module and the basic functions are running smoothly.
For original design, schematic and so forth, refer to:
http://yusynth.net/Modular/EN/DIVIDER/index.html
There's a reset circuit which takes an external signal and produces a short trigger to reset all three counters -- however, this occurs on the falling flank of the reset input gate/trigger/whatever. I want the pulse to happen on the rising flank instead (and I reckon that this would be considered as 'proper' behavior of such a feature).
Any suggestions on how to fix that without changing too much of the original circuit?
(This behavior is supported by simulation, too. I've replaced the NPN Q11 with a PNP -- and this somehow 'works' but is hardly good practice due to somewhat ambiguous levels rather than 0 and 15V)
Greetings,
helix
EDIT: set description to '[SOLVED]'.
Audio files: 643
PostPosted: Thu May 03, 2018 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
a PNP transistor is a step in the right direction, but also connect R42 to +Vcc instead of GND.
You might have to add a resistor in series with the base of Q11 as well. It does make some
sense to have it reset on the high-to-low transition but I always use low-to-high myself.
helix_modular
PostPosted: Thu May 03, 2018 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ace, PHOBoS!
Simulation is affirmative. Apparently I don't even have to modify the values... I'll try it out asap irl and report back.
All the best,
helix
helix_modular
PostPosted: Mon May 07, 2018 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks again PHOBoS. It works exactly as you suggested.
This is what I've done:
1) Replaced Q11 with an PNP (BC557C)
2) Rotated Q11 by 180° (i.e. swap emitter and collector)
3) Connected the centre pin of Q11 (base) with R42 (22k) to Vcc+
4) Done
I've uploaded my stripboard design to this thread:
http://electro-music.com/forum/topic-69935.html
helix
Audio files: 643
PostPosted: Mon May 07, 2018 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
good to hear it works Very Happy
