today> Tom Bruce and Rob Snyder High Anxiety Cabaret
Display parameter?
Page 1 of 1 [2 Posts]
the19thbear
PostPosted: Fri Apr 20, 2018 12:08 am    Post subject: Display parameter? Reply with quote  Mark this post and the followings unread
Hi. Just go the Nord Modular G1, and I am really suprised at how good it actually sounds.
There is just one thing (for now) that i'm wondering about. Is it possible to display the parameter name for the knob you are changing on the actual hardware?
Let's say i have assigend the freq of a filter to knob 1.
THen when I turn knob one on the hardware, i want "Freq" to display in the small hardware display.
Is that possible?
Otherwise I need to get a hold of some overlays that I can print out and put on the nord. Anybody ever made those?
I'm REALLY happy about getting this box! This is such a cool underrated machine.
agustindead
PostPosted: Wed May 16, 2018 6:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
a bit late of a reply, but you can see the name of the module and its parameter when in edit mode. you can rename all modules so it's more helpful... also, I sometimes use a constant module (renamed CUTOFF, for example) and route it into a modulation input. I found this make things clearer when in edit mode, though it's not always necessary.
