  Various Artists Live Stream Jam
Arduino based DVM for synth/audio--analog TFT meter?
Page 1 of 1 [4 Posts]
cslammy
PostPosted: Fri Jun 15, 2018 8:43 am    Post subject: Arduino based DVM for synth/audio--analog TFT meter? Reply with quote  Mark this post and the followings unread
Hey folks--trying to create this and I am stuck on the VU meter itself....getting the Y axis to work.
For full details about what I am stuck on, Please take a look at my blog to see what I am stuck on if you have time. The problem is a bit complex and is driving me bonkers. Confused
http://audiodiwhy.blogspot.com/2018/06/synth-dvm-part-iii-vu-blues.html
In a nutshell, I am using Adafruit GFX library with a nano. This library is super easy to use but as far as I can tell it can't create diagonal lines of a consistent length without some hacking. And that's what I need....
So meter needle length isn't correct--Y is a constant value and shouldn't be--in the real world an analog meter needle is always the same length!
Can anyone please suggest a good way to fix this? I am a decent coder for Arduino but not great having just started using these handy devices a couple of months ago. Willing to learn! Thanks in advance.
 Filesize:  139.44 KB
 Viewed:  235 Time(s)
please visit my AUDIODIWHY blog and website
Audio files: 29
PostPosted: Fri Jun 15, 2018 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
The fastest way to accomplish this is to make an array with the x and y coordinates for all voltage inputs. Similar to a lookup table for waveforms.
That way no (s l o w ) calculations with sin/cos are necessary.
my synth
cslammy
PostPosted: Fri Jun 15, 2018 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the quick response.
I'll look into using an array for the Y coordinate as it sweeps between 0 and 1023 for X and post whatever I find.
cslammy
PostPosted: Fri Jun 15, 2018 9:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Grumble, good advice, the array did the trick!!! Very Happy
Thanks! I'll post what I ended up using on my blog.
