mph
Posted: Wed May 18, 2011 2:56 pm Post subject:
brother303 wrote: |
Which 082 exactly? The lower one (next to the lp/bp/hp-outs) on the left side on Lucas´ v3-pcb? |
Nope, it's the 82 which is on the middle of the left side of the pcb (U4 on the corrected schemo). The one which has three 200K resistors connected to its pin 3 on the pcb. That's the mix input section of the circuit and not the output.
You can compare to the wiring of the other 82 in the LP/BP/HP output section which is correctly connected (U5 on the corrected schematic): pin 3 should be connected to ground. |
brother303
Joined: Nov 02, 2010 Posts: 139 Location: ruhr-area/germany
Posted: Wed May 18, 2011 4:55 pm Post subject:
thanks mph,that`s what I needed to know.
Cheers!
_________________ Best regards
Greg |
Luka
Luka
brother303
Posted: Sat May 21, 2011 8:41 am Post subject:
thanks for offering this update,cool!
No more bugs and kludges now?
Thank god,I didn´t etch the older version ´til now...
Cheers. _________________ Best regards
Greg |
Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
Posted: Sat May 21, 2011 11:19 am Post subject:
I'd love to see a dual version like Verbos' but with the multiple output types, perhaps using a single buffer with switching for the Type. Of course, it's always nice to have independent outputs... _________________ We are selling emotions, there are no emotions in a grid. -mwagener
"IC 741. Sometimes you don't want fidelity." -Small Bear Electronics Catalog |
Luka
Posted: Sat May 21, 2011 3:08 pm Post subject:
brother303 wrote: | Hi,
Cheers. |
cant be sure - i haven't tested it and wont have time until 2013 as i'm about to travel overseas for a few years - my studio is all packed up. _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
Peake
Posted: Wed Jun 29, 2011 3:34 pm Post subject:
Danger! Don't etch this! Am having slight size alterations occur when going from photoshop to pdf, and ICs won't fit correctly. Huge apologies to anyone who might have done so; from now on I'll etch and confirm everything prior to posting.
Needing ideas please...
I'm working on revising Mark Verbos' 291 filter dual layout because it's sized for Buchla systems (4" x nearly 6"). I like the idea of a single board, or even stacking two boards for a quad setup on a single width panel.
I've built and enjoyed the Stites/Luka/etc. modified versions of Mark's board, with the buffers for LP and HP, and had wanted that and a mixer either per filter or available in a quad concept for summing, or for merely adding LP and BP for variable notch response in any single filter, then summing, etc.
So, I've added Luka's adaptation of Ken Stone's DC mixer, as well as individual buffers for this particular board size, then went a little nuts and changed the mixer in the first filter to a slightly modified MXR distortion +. It would be nice to have something like a RAT per filter, but that's a 308 opamp, and I've just used the sections of a TL084 instead.
Now, the Distortion + uses a 741 with a 9V battery, and 4.5V into a 1M to the input. The 084 is of course using 15V bipolar rails and has several times the slew rate of the 741, meaning a crisper sound (not necessarily desirable here). I'm asking what proportion is required for the 4.5V section, with the main voltage nearly twice that of the original design. Just double it to 9V and it should be well? I wanted to ask before etching, although I'll likely just have to etch and tweak anyhoo.
Also, I have one unused opamp section in the one filter and wanted to see if anyone had any sweet ideas for it (HF boost/cut, etc.) in the available space. I can see how to further tighten the distortion layout to allow a little more room for that open opamp. "What would you do?"
Thanks to all who have brought this design to this point!! I haven't added a wiring diagram as the core is still unproven. Here is the Distortion +:
http://www.premierguitar.com/Magazine/Issue/2008/Dec/MXR_Distortion_Plus_Mods.aspx
Description: |
Download |
Filename: |
291 Dual 2.pdf |
Filesize: |
4.79 MB |
Downloaded: |
807 Time(s) |
numbernone
Joined: Aug 16, 2006 Posts: 477 Location: new york city
Posted: Tue Aug 09, 2011 6:40 pm Post subject:
Assembled the third from my original 3 boards of 2007, has it really been so long?? WOW
So this one is again different from the other 2. Probably the most straitforward sounding of them the 3. HOWEVER this guy just wont go to the bottom like the other 2. I tend to the HP output and love to sweep the bass frequencies away and have them come rushing back with a WHOOMP. This one just. almost makes it but not quite. Mind you it will pass low frequencies, it just doenst not emphasize them like the other 2 will. Not really sure where to proceed to try and get some additional bottom. |
xi-boy
Posted: Mon Aug 22, 2011 5:26 pm Post subject:
Luka wrote: | here you go
v4
fixed the mixer section - didn't change anything else
it would be nice to completely redesign this pcb so it doesn't have all the wire links. i tried to maintain mark's filter section and it made it hard to add lots of extra circuitry without wasting space. |
hi
i am a little bit confused about the potiometer values of the current version
its still
r47 100k lin
r7 resonance 5k
r47 fm level 50k lin
r37 initial cent freq 10k lin
r40 center freq 10k lin
r41 initial bandw 10k lin
r44 band mod level 10k lin
thanks a lot |
thermionicjunky
Joined: Dec 07, 2006 Posts: 90 Location: san francisco
Posted: Tue Aug 23, 2011 8:11 am Post subject:
xi-boy wrote: |
hi
its still
r47 100k lin
r7 resonance 5k
thanks a lot |
Those values work for me. |
xi-boy
Posted: Tue Aug 23, 2011 10:41 am Post subject:
great. thanks |
L´Andratté
Joined: Sep 23, 2012 Posts: 150 Location: Hamburg, Germany
Posted: Sun Mar 02, 2014 6:25 am Post subject:
I have just breadboarded the circuit from the Scott Stites schematic and am positivly blown away by the beautiful sounds of it, I´m totally in resonance!
Now being a analog freak, I have to understand how it works, but altough I thought I had knowledge of the vc filter topologys, I´m kind of clueless with this one, it looks a bit like a heavily modified state variable...
Please is there anyone willing to me? |
Snaper
Posted: Thu Oct 09, 2014 3:33 am Post subject:
v4
Have somebody wiring diagram for this one? |
fuji
Posted: Thu Jun 28, 2018 3:27 am Post subject:
Hi anyone can help please ?? Do I should connect bp, lp, and hp to the 3 mix in points?? thanks!! |
Fernando
Joined: Dec 30, 2006 Posts: 286 Location: Barcelona & Emporda, Spain
Posted: Thu Jun 28, 2018 3:58 pm Post subject:
fuji wrote: | Hi anyone can help please ?? Do I should connect bp, lp, and hp to the 3 mix in points?? thanks!! :) |
This filter is a BP one. The main output is the BP.
The LP and HP outputs are tapped from two points of the circuit and each one uses a buffer both to avoid influence on the filter and to adapt the level.
I don't see the mixer you mean.
The only mixer in Scotts schematic is for the input, not the outputs _________________ Fer
fuji
Fernando
Posted: Sat Jun 30, 2018 11:36 am Post subject:
fuji wrote: | hi thanks for reply!! :D so whit this basic layout it should work?
Fernando wrote: | fuji wrote: | Hi anyone can help please ?? Do I should connect bp, lp, and hp to the 3 mix in points?? thanks!! :) |
The only mixer in Scotts schematic is for the input, not the outputs |
You are using Mark Verbos pcb, which reflects Verbos schematic (= Buchla schematic with the dual FET erased and substituted by an op amp twice)
Scott's one is a modern redrawn of Verbos schem, aditionally showing the LP and HP taps and a buffer for each, plus an input mixer. It looks clearer to me.
Compare both schematics.
It is really enriching to look at both schematics plus the Buchla original.
Also check Ebolatone's blog for CV input resistor values, etc: http://ebolatone.blogspot.com/2013/06/j3rks-291-clone-build.html
he is using J3RK pcb, but refered to same circuit/schematic _________________ Fer
. Last edited by Fernando on Sat Jun 30, 2018 3:07 pm; edited 17 times in total |
Fernando
Posted: Sat Jun 30, 2018 11:54 am Post subject:
FM-input pot wiring is wrong in your drawing - compare with schematics:
you should exchange conections on the pot (the two not being ground). Center leg (wiper) is what should connect to the circuit and the banana to one side of the pot.
The rest looks good to me (to me : )
BTW, you could implement the 100k trimmer at the main audio input as a 100k panel pot, "in-trim" in your Verbos pcb drawing.
(looking at the Buchla and Verbos schematics; Verbos pcb in your drawing is based on that. Scott schematic has an input mixer, so input is slightly different)
And the 5k "Q" trimmer as a panel pot too ("res" in your Verbos pcb drawing) See below.
This trimmer (5k) is intended to be set this way (as per original Buchla schematic):
"trim for no oscillation at 2kHz with 2kHz signal input and minimum bandwidth"
One could implement it as a panel pot and mark on the panel the point where this setting is right, to have a reference mark for the "originally intended" response.
fuji
Fernando
Posted: Sun Jul 01, 2018 4:49 am Post subject:
- I would let alone the FM input, same as the original. It was intended for audio signals (*) to modulate the cf in addition to a CV on the cf CV input, which already has attenuator/inverter and offset controls. Of course you can modulate it with an AC control voltage too or a very low freq audio signal. So I (I : ) would not add anything to this input.
You could tweak the values of C8 and R45 to achieve the response you like for this input.
* (take a look to a Buchla 291 original panel: FM input is a jack, not a banana)
- I preffer the input of this filter as per the original (100k trimmer or 100k pot) So I would not implement (again, I : ) the input mixer as per Scott schematic.
I'd rather build a mixer on the same panel with inverting capability (to be able to have VC resonance using an VCA, among other things) and a bit of gain. Two or three channels that can go from -1.5 to +1.5, it's just a dual op amp, same as a Serge processor/mixer, as in here:
https://www.cgs.synth.net/modules/cgs04_mix.html
but choosing the resistors for 1.5 gain instead of unity (so it will go from -1.5 to +1.5) and using the "processor" inputs (in red), not the normal ones.
Gain of 1.5 is just an idea, it could be just unity; the filter is by itself very hot (it can go to 20Vpp output for 3Vpp input with certain settings/signals)
Again, this mixer/inverter being a separate circuit and leaving the 291 input as per the original.
- I don't understand why you connect the BP out to the input of the filter??? (the red line in your drawing)
- Problems were reported here http://ebolatone.blogspot.com/2013/06/j3rks-291-clone-build.html
when using a dual op amp to implement the two buffers for LP and HP outs.
You better use two single op amps now that you will etch your own pcb.
- You better use 07x instead of 08x
fuji wrote: | yes Fernando I agree everything you said... btw I checked all the schematics and pcbs and made this new layout (last one has few errors)...the only missing part is the optional cv processor section
Fernando wrote: | FM-input pot wiring is wrong in your drawing - compare with schematics:
. Last edited by Fernando on Sun Jul 01, 2018 10:11 am; edited 5 times in total |
fuji
Posted: Sun Jul 01, 2018 5:29 am Post subject:
hi Fernando , the out pin on the top of the pcb is the simply out of the input mixer/buffer (it is not the out of the 291)... so you can connect it or not to the input of 291 (i think i will bypass it using only a 100 trimmer as you said - and bypass also the cv fm in section)..the real bp filtered out is the one on the left
Fernando wrote: | - I would let alone the FM input as it is. It was intended for audio signals to modulate the cf in addition to a CV on the cf CV input, which has attenuator/inverter and offset controls already (take a look to a Buchla 291 original panel: FM input is a jack, not a banana) Of course you can modulate it with an AC control voltage too or a very low freq audio signal. But I (I : ) would not add anything to this input.
I'd rather build a mixer on the same panel with inverting capability (to be able to have VC resonance using an VCA, among other things) and a bit of gain. Two or three channels that can go from -1.5 to +1.5, using a dual op amp, same as a Serge processor/mixer, as in here:
- Someone reported problems (read this thread carefully) using a dual op amp to implement the two buffers for LP and HP outs. You better use two single op amps now that you will etch your own pcb.
fuji wrote: | hi thanks for reply!! so whit this basic layout it should work?
Fernando wrote: | fuji wrote: | Hi anyone can help please ?? Do I should connect bp, lp, and hp to the 3 mix in points?? thanks!! |
Fernando
Posted: Sun Jul 01, 2018 5:32 am Post subject:
fuji wrote: | hi Fernando :lol: , the out pin on the top of the pcb is the simply out of the input mixer/buffer (it is not the out of the 291)... |
oh ok :D
But if you implement Scott's mixer then you have to build the input as per his schematic. Note it is not the same as the Buchla/Verbos schem.
It has a pull-down 100k resistor and not the 100k trimmer, etc. _________________ Fer
eurocrack
Posted: Sat Nov 28, 2020 4:07 pm Post subject:
Hey, sorry for necro-ing this post a bit.
I was wondering if one can get this vcf to ping?
cheers |
