gabbagabi
Joined: Nov 29, 2008 Posts: 651 Location: Berlin by n8
Joined: Nov 23, 2015 Posts: 1294 Location: Netherlands
Posted: Sat Jun 30, 2018 11:03 am Post subject:
or you might add a cd40175 quad flip-flop and it will never forget _________________ my synth |
elektrouwe
Posted: Sat Jun 30, 2018 1:30 pm Post subject:
get rid of the TL071 and use a noninverting buffer (spare gate, or 2 inverting in series) instead. With a feed forward resistor of 100k between in and out of the buffer the caps (100nF then) will "autorefresh" forever.
I have a similar touch sequencer: Instead of switches there is a SET and a RESET touch input. each connected via diode to the storage cap.
SET diode direction is cathode to cap, RESET diode is connected anode to cap. And there is TOUCH electrode connected to a square wave oscillator. When I touch this electrode with my left hand and either a SET or RESET einput with the right hand, I can program the sequencer.
cap values must be small (nF range) because skin resistance is high. A more reliable solution is to use a "stylus" conneted to the square wave osc. and touch the SET/RESET inputs with it. Then100nF caps are ok. |
Audio files: 705
Posted: Sun Jul 01, 2018 4:02 am Post subject:
I'd go with some flip/flops too. Besides being more reliable you can toggle between set/reset with a single button.
The comparator on the output is not a bad idea in this case.
elektrouwe wrote: | With a feed forward resistor of 100k between in and out of the buffer the caps (100nF then) will "autorefresh" forever. |
hmm so that would be from the gate output back to the common (Y) of the mux ? at least that's how I think it could work . _________________ "My perf, it's full of holes!"
Audio files: 278
Posted: Sun Jul 01, 2018 7:10 am Post subject:
Hmm .. I like that idea - sequences that forget :-) _________________ Jan
Audio files: 705
elektrouwe
Posted: Sun Jul 01, 2018 9:57 am Post subject:
PHOBoS wrote: | I'd go with some flip/flops too. |
well, "some" means 16; not a small #
PHOBoS wrote: | hmm so that would be from the gate output back to the common (Y) of the mux ? . |
yes |
elektrouwe
Posted: Sun Jul 01, 2018 10:01 am Post subject:
Blue Hell wrote: | Hmm .. I like that idea - sequences that forget |
you don't play live in front of a dancing crowd, don't you ? |
Audio files: 278
Posted: Sun Jul 01, 2018 1:17 pm Post subject:
erm I like the idea of sequencers that forget _________________ Jan
gabbagabi
Posted: Tue Jul 03, 2018 12:58 am Post subject:
Yes, a little...
Remove R12, there is no need for that resistor and adds just a parallel impedance to the capacitors. _________________ my synth |
elektrouwe
Posted: Tue Jul 03, 2018 1:35 pm Post subject:
g.gabba wrote: |
what a great idea with the feed-bag, would than this also work somehow? |
no, won't work. you need positive feedback (noninverting Schmitt-Trigger) |
IGR
Posted: Wed Jul 04, 2018 7:46 am Post subject:
Does anyone know the sequencer of the Leploop V1? I think switched capacitance analog shift register is used there. This term was until today a bit mysterious to me. Thanks friends! |
elektrouwe
Posted: Wed Jul 04, 2018 10:27 am Post subject:
IGR wrote: | ...Leploop V1? I think switched capacitance analog shift register is used there. .. |
didn't know this sequencer yet. google found " the LEPLOOP has a 16-step analog recorder, much like an analog delay.Over time, as the analog sequencer cycles through its pattern, the signal will degrade and the sound will hange. This is because the capacitor can only store the signal for a limited amount of time"
for a step sequencer storing only 0V and VDD, refreshing the memory is easy with a noninverting Schmitt-Trigger as described above. For real (quantized) analog storage you would need an ADC that reads
the actual (already slightly drifted) analog voltage and refreshes the original voltage with a DAC. I've sketched a 3bit solution with 8 comparators and a 8/3 decoder as ADC and a 4051 with linear R string as DAC.
But in microcontroller days it's too much effort to do it Lunetta style. Last edited by elektrouwe on Wed Jul 04, 2018 12:31 pm; edited 2 times in total |
IGR
Posted: Wed Jul 04, 2018 11:37 am Post subject:
Clearly, I understand. But I find MUX as bidirectional switch for read/write operation very simple, useful. During ~10% of CV step duration to read voltage by S&H, then during 90% of CV step write its value back to capacitor. At output will be while whole step duration still right CV value. Maybe 4066 switch or FET controlled by short monostable triggered by clock. Touch sensitive CV sequencer that´s exciting idea. To be able to "tune" sequences on the fly with finger pressure, something like to inflate tyres at pump +/-! Impro friendly piece of gear. |
Audio files: 278
Posted: Mon Jul 09, 2018 3:39 pm Post subject:
I've made a leaky gate sequencer for my soft synth .. its doing nice stuff .. but am not totally happy yet with the forget curves .. too abrupt ... also I want negative forget .. negative leakiness ... as in that it can grow back from sparse to the programmed pattern. So still experimenting a bit with it .. but what a nice idea :-) _________________ Jan
gabbagabi
Posted: Tue Jul 10, 2018 11:14 pm Post subject:
iam glad to hear it is something enjoyable:-)
we need voltage controlled leakyness, in the negative half it will forgett more and more, in the positive it will look into the future more and more
or in reality one could connect a vca to the falling voltage in the cap so it would fade out before forgetting, somehow at least |
gabbagabi
gabbagabi
Posted: Wed Jul 25, 2018 9:08 am Post subject:
i exanded the concept a bit, now it is gate+cv.
will post it soon.
