Hammer
Joined: Mar 13, 2018 Posts: 72 Location: Russia, Zhukovsky
Posted: Sat May 26, 2018 4:56 am Post subject:
RhythmMaster 85 |
Hello!
This is RhythmMaster 85S (S mean simplified) device. It makes hi-hat and snare beats out of white noise generated by TL-431.
Full version have external clock source and bass drum generator with sidechaining feature. Still in progress.
1. When you will turn on this device, you will hear white noise with periodic scratches. If you do not hear the scratches, just wait until ATTiny85 will warm up or cold down.
2. Turn the knob, it will change beats.
3. Push the buttont once, it will change knob mode. In this mode turn the knob, it will change decay.
4. Push the button, hold it and turn the knob, it will change tempo.
Code: https://github.com/youcantignoremytechno/RhythmMaster_85S
Description: |
Filesize: |
248.08 KB |
Viewed: |
621 Time(s) |
Description: |
RhythmMaster 85S circuit diagram |
Filesize: |
91.07 KB |
Viewed: |
717 Time(s) |
Hammer
Posted: Sat May 26, 2018 4:59 am Post subject:
To make it more interesting, play with envelope forms and noise timbre.
Examples:
Description: |
Download |
Filename: |
rhythmmaster_85s_vinyl_noise.mp3 |
Filesize: |
94.68 KB |
Downloaded: |
797 Time(s) |
Description: |
Download |
Filename: |
rhythmmaster_85s_beats.mp3 |
Filesize: |
388.99 KB |
Downloaded: |
779 Time(s) |
Description: |
Download |
Filename: |
rhythmmaster_85s_tempo.mp3 |
Filesize: |
162.56 KB |
Downloaded: |
808 Time(s) |
Description: |
Download |
Filename: |
rhythmmaster_85s_decay.mp3 |
Filesize: |
262.92 KB |
Downloaded: |
745 Time(s) |
StormB
Posted: Tue Jun 12, 2018 6:37 am Post subject:
Hi Hammer,
wich Bootloader need 1 or 8 MHZ ?
and how much for the Sketch 16 MHZ? |
Hammer
Posted: Tue Jun 12, 2018 6:58 am Post subject:
I'm always using 16mHz. In this project you don't need bootloader, because there are no USB port, only power from USB. Use another Arduino as programmer or use USBasp - the best. |
StormB
Posted: Wed Jun 13, 2018 5:55 am Post subject:
Hidiho Hammer,
wich transistor is right 2x 3904 npn or 2x3906 pnp
in your schematic you have 1 x3904 and 1x3906
but the symbol is for 2 x3906
thanks
StormB |
Hammer
Posted: Wed Jun 13, 2018 6:53 am Post subject:
Sorry for mistake! I've update circuit diagram.
Left - 2N3904 NPN, Right - 2N3906 PNP |
Hammer
Hammer
Posted: Mon Jul 16, 2018 6:00 am Post subject:
I've used for tom/kick Wien bridge based oscillator. I'ts working great with 4069. Only sidechaining part of the main circuit still isn't ready.
But I started to make case out of e-bike controller box. Sides are laser cutted vinyl.
Description: |
Filesize: |
6.51 KB |
Viewed: |
15741 Time(s) |
Description: |
Filesize: |
667.16 KB |
Viewed: |
555 Time(s) |
Description: |
Filesize: |
644.83 KB |
Viewed: |
522 Time(s) |
Hammer
Audio files: 705
Hammer
Posted: Sun Jul 22, 2018 9:06 am Post subject:
Thank you, PHOBoS!
A lot of interesting stuff could be cutted out of vinyl: https://www.instagram.com/youcantignoremytechno/
But it's not easy beacuse of releasing chlorine and condensating hydrochloric acid. CNC should be very good oiled, smoke should not stay in the room. Otherwise everything will be covered by rust. |
Hammer
Hammer
Hammer
Hammer
Hammer
Posted: Mon Aug 13, 2018 2:44 am Post subject:
I've made the 4069 VCA for BassMaster:
I think, that this is the way to shrinkify RhythmMaster! |
Hammer
