Trouble shooting : ACME4 LPX Setup
Page 1 of 1 [2 Posts]
jon909
PostPosted: Fri Jul 27, 2018 3:43 am    Post subject: Trouble shooting : ACME4 LPX Setup
Subject description: Having trouble sync ACME4 with DAW
Greetings to All,
My first post here, to all ACME4 users, hope you guys will be able to charm in, Thanks in advance.
I have been trying without success for weeks having LOGIC as the master to ACME4.
There is a known problem with the SND plug-in with LOGIC, apparently, the problem comes from LOGIC. In the DAW, I have no option to launch the plug-in on a track, except as an effects unit. Apparently, there's still a workaround using the plug-in. Didn't manage to get that to work as well : (
My last resort: -
i created a 16th tick loop audio file on an Audio track within LOGIC and looped it for as long as the project runs. Using the audio output to sync with ACME4.
Btw, The audio sample I used to loop was downloaded from SND website.
I also make sure LOGIC doesn't transmit Midiclock or any kind of sync messages out to ACME4 via USB. (The ACME4 is powered by the computer)
All the above with no success.
Are there any settings on ACME4 I need to set before launching LOGIC? or any other options I should explore?
Highly Appreciate for Anyone with the similar setup to share some thoughts.
Peace
JY
jon909
PostPosted: Fri Jul 27, 2018 11:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got it working!
Using SND plugin as an effect device, I was looking for the plugin as Software Instrument instead of EFX since it generates Audio.
Cheers!
Peace
JY
