today> Twyndyllyngs Live - special shelter in place episode with Ninjam Chez Mosc
 Forum index » Online Music
AlanP's Awfulness
Page 3 of 3 [60 Posts]
Goto page: Previous 1, 2, 3
Audio files: 39
PostPosted: Tue Aug 14, 2018 12:07 am    Post subject: Reply with quote  Mark this post and the followings unread
The Gate Out of Stage 1 went to trigger the Elements input on the switch, Gate Out of Stage 5 went to trigger the Braids input on the switch. I could have ran the clock into a divide by 4, but then I might have sync issues.
Elements wound up going into the CGS60 Stompbox Adaptor, purely for additional gain to ramp it up to Braids' level. The minor shimmer in it's chuffs was from a LFO into the Tone CV for the Blow exciter. (The moving tone in the exciter has an effect on the resonator section in turn.)
I tried running the final mix into the Serge Resonant EQ to get rid of that minor blip when going from Elements to Braids, but no luck. I also tried delaying the Gate Out of Stage 5 a little bit (run that into the Gate In of the Rampage, run the Falling output of Rampage into the switch trigger, play with the Rise time to get a gate delay), but that also didn't do much. I'll have to think about it.
Audio files: 29
PostPosted: Tue Aug 14, 2018 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
AlanP wrote:
Chuff sounds was Elements, chord sounds was Braids in three-saw mode with the other two saws tuned lower and lower again, then run through a reverb.
Great sounds! Very Happy
my synth
Audio files: 39
PostPosted: Fri Nov 09, 2018 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dad was around today, and I had some fun putting a patch together.
Changes roughly just after 4min into it.
 Filesize:  306.33 KB
 Viewed:  274 Time(s)
2018-11-10 dadfun.mp3
 Filename:  2018-11-10 dadfun.mp3
 Filesize:  7.88 MB
 Downloaded:  756 Time(s)
Audio files: 29
PostPosted: Fri Nov 09, 2018 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can’t play it right now, one of the dogs starts barking when I play this...
Shocked
my synth
Audio files: 257
PostPosted: Sun Nov 25, 2018 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some nice Awfulness there :-)
(and can't blame the dogs for recognizing the sounds)
Audio files: 39
PostPosted: Tue May 14, 2019 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Had another play with the Appendage Touch Controller today. I'm not sure... but when I take my finger off the ribbon, sometimes the CV will drop very low, riiiight on the very end before the Gate goes low. In this patch, it was controlling Mutable Elements. (Pho, you really need to build this one!)
Erm, the background sequence is mainly to give me a beat, not for a melody to bounce riffs off.
I messed with the Contour knob on Elements a couple times.
2019-05-14 testtouch.mp3
 Filename:  2019-05-14 testtouch.mp3
 Filesize:  5.92 MB
 Downloaded:  486 Time(s)
Audio files: 39
PostPosted: Sat Apr 25, 2020 11:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Short test of the snare, hi-hat (both open and closed), and the Bastl Tea Kick because why not. All sequenced by the mighty Per|former sequencer.
2020-04-26 drum test.mp3
 Filename:  2020-04-26 drum test.mp3
 Filesize:  904.97 KB
 Downloaded:  58 Time(s)
Audio files: 650
PostPosted: Tue Apr 28, 2020 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds great alan
Audio files: 39
PostPosted: Thu Jun 18, 2020 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two NLC Triple Sloths modules were the core for this.
Voice A - 258 dual osc, one side's audio going into the FM for the other side (that I took the audio output from), going into the 291 Bandpass, then off to the output module.
Voice B - Braids, into Yusynth ARP4072, then output module.
Voice C - Haible Living VCOs, into audio mixer, into Yusynth Minimoog VCF, into output module.
All with liberal amounts of CV from the two triple sloths module.
2020-06-19 two triple sloths.mp3
 Filename:  2020-06-19 two triple sloths.mp3
 Filesize:  21.98 MB
 Downloaded:  37 Time(s)
Audio files: 39
PostPosted: Fri Jun 26, 2020 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
208 Stored Program Sound Source with a basic krell patch, going through the MTM Reverb (wet/dry controlled by the 266 FRV.)
The 208 isn't completely finished, yet, still waiting on the spring tank.
 Filesize:  379.82 KB
 Viewed:  6 Time(s)
rec_20200627-104008_1.mp3
 Filename:  rec_20200627-104008_1.mp3
 Filesize:  17.65 MB
 Downloaded:  33 Time(s)
