Ayab
Posted: Wed Aug 15, 2018 3:15 pm Post subject:
Hi AlanP
Great project.
I'd be interested in a set of pcb's and a panel
MapacheRaper
Posted: Mon Aug 20, 2018 6:28 am Post subject:
Idem, I would go for one or two PCB sets depending on price.
Do you have the BOM to take a peek? |
Ayab
Posted: Mon Aug 20, 2018 8:34 am Post subject:
LFLab wrote: | MapacheRaper wrote: | You are doing a fantastic work!
If you plan to sell PCBs when they are ready please put me in the list. This module is like a 2x version of Maths, more or less, isn´t?
Maths also has 4 attenuaverters, voltage control over cycling, analog logic, and summing signals. But yeah, it is a start |
I have not used "Maths" what is the main functionality advantage over this? |
Joined: Mar 11, 2014 Posts: 746 Location: New Zealand
Posted: Sat Aug 25, 2018 8:13 pm Post subject:
Maths has offset and a mixer built into it, apart from the Peak Out, this does not. (I don't own Maths, so can't really speak to it.)
I'm waiting on some 3296P trimmers to arrive so I can check their fitment on my 0.3 boards (I used some RV36 trimmers, they don't fit quite right), and then I'll order ten sets of revised panel and PCBs. |
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Tue Aug 28, 2018 3:32 am Post subject:
Ayab wrote: | LFLab wrote: | MapacheRaper wrote: | You are doing a fantastic work!
Rather than "just" create a voltage which goes up and then down (under voltage control), one can create much more complex modulation voltages (I do not have Maths myself, but there are youtube videos), by combining the outputs of individual slope generators or external control voltages. |
MapacheRaper
Posted: Tue Aug 28, 2018 6:19 am Post subject:
There´s a virtual modular called VCV RACK. Befaco itself have programmed a software version of Rampage, which is quite similar to Maths, so you can play with the module in digital before purchasing it.
I didn´t got Maths untill I played the digital Rampage. Now Im looking to build one. (Rampage) |
Posted: Sat Dec 01, 2018 6:43 pm Post subject:
Ordered a set of new revision boards (v0.4). Fixed the insanely close vias on EngA PCB, and also added holes for the LEDs in the front panel
Just uses usual components, and LM13x00 OTA, not the CA3080. The switches on it are Tayda solder-lug type.
I'll update again once I've verified this new revision. |
MapacheRaper
Posted: Sun Dec 23, 2018 7:03 am Post subject:
I read it on the phone and seemed all correct and tasty |
Ayab
Posted: Sat Jan 05, 2019 2:46 pm Post subject:
Hi Alanp
Read through doc's twice: Excellent, concise and easily understood. You have obviously very carefully written the doc's they are a perfect walk through of the build so that problems can be avoided - imho they are really good.
Please confirm me as a customer |
Ayab
Posted: Fri Mar 01, 2019 8:03 am Post subject:
Just received a pcb and panel set from Alanp - arrived in about a week from NZ.
Very happy with the quality of the aluminium panel and the pcb's.
Going to be a pretty crowded panel but should be easy to get used to as it is duplicates of the same functions.
