MIDI 2 CV recommendations?
Page 1 of 1 [5 Posts]
MapacheRaper
PostPosted: Thu Sep 13, 2018 1:51 am    Post subject: MIDI 2 CV recommendations? Reply with quote  Mark this post and the followings unread
I have an arduino nano and 2 MCP4752 boards. I would like to build a MIDI to CV module for eurorack. Ideally 2 channels with 2 gates, but I will try 1 cv 1 gate first on the breadboard.
If someone has suggestions Im all ears.
cslammy
PostPosted: Sun Sep 23, 2018 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's something to get you started using ATTINY.
https://janostman.wordpress.com/cheap-diy-usb-midi-to-cv-interface/
please visit my AUDIODIWHY blog and website
MapacheRaper
PostPosted: Sun Sep 23, 2018 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, that looks economical and easy. I love it.
It has 8 bits of reso, thought, that could be a bit too little, maybe. Is there any way to get more resolution? Interfacing it with the MCP4752 would be spot on, but I guess I would have to modify the circuit and the code, isn´t?
Anyway Im triying this for sure. Thanks!!
cslammy
PostPosted: Mon Sep 24, 2018 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes you'd have to modify the code to get more resolution, but if I'm reading this correctly dspsynth.eu has hacked 8 bit to work.
You'd need to check into the "BroHogan" tinywire library for ATTINY for starters I'd guess. That should allow I2C calls to something like the MCP4725 D/A.
MapacheRaper
PostPosted: Fri Oct 19, 2018 4:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I have 2 of these. Im trying the same 8bit design of janostman, and Im almost there, but when compiling the code i get
'TCCR1' was not declared in this scope
Which seems related to some library or maybe the micronucleous programmer that Im not sure if I have installed correctly.
Anyone knows how to program it?
