FS [EU] - Big Remodelling Sale!
Page 1 of 1 [2 Posts]
paugui
G2 patch files: 37
PostPosted: Sat Aug 11, 2018 10:58 am    Post subject: FS [EU] - Big Remodelling Sale! Reply with quote  Mark this post and the followings unread
Hi all
In order to remodel my studio and improve my workflow, I have the following gear available for sale:
Keyboards:
Korg Karma - 500€ (750€ with EXB-PCM02 and EXB-PCM03 in NOS condition)
Keys a bit yellow, with one of them slight lifted, but working well otherwise.
Effects processors:
Rockman Pre-Amp - 40€
Portable Pre-Amp with Chorus, Delay and Overdrive.
Good shape, but it is a bit noisy (nothing special, but it could be cleaner)
Yamaha FX900 (x2 + FC900) - 200€
Need some repairs as the jack connectors and back switches fail a bit, which leads to volume drop outs and other problems… But the unit itself is in good shape and works as it should… The cable for the FC900 is missing, unfortunately…
Drum controllers:
DrumKAT EZ - 175€
Needs some repair as pads 1 and 2 don’t work, but the rubber is in good condition (it was barely used…)
Never checked what was the problem, but might be either some soldering that needs to be redone or the whole FSR that needs replacement.
Comes with original box!
TomKATs (4x7” and 3x11”) and KicKAT by Dauz - 175€
Pads in good shape (except the KicKAT which has some small rust spots), barely used and some even come with the original box!
Others:
Korg EXB-PCM02/03 - 300€ (750€ together with the Korg Karma)
These are just like new, in original box with all original content available, you just won't find any that is in better shape!
Were only tested once on my Korg Triton Pro and have been stored away ever since.
Since the price is a bit high (due to the amazing condition they are at), I can likely accept any reasonable offer on them to get a deal done fast!
Items are located in Portugal, but I can send them worldwide (despite the prices will likely be a bit high if you are living outside the EU).
Final shipping prices will depend on what you want, but should be possible to keep them around 30€ for most countries in the EU.
For any further info, photos or demos, just contact me directly!
Best to all
Paulo
paugui
G2 patch files: 37
PostPosted: Fri Oct 26, 2018 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Upa, some stuff gone while other was added!
