G2 keyboard frozen at startup
optical
PostPosted: Sun Nov 04, 2018 8:15 am    Post subject: G2 keyboard frozen at startup Reply with quote  Mark this post and the followings unread
There's an old pinned thread on this, but I've been hit with the same issue and none of the solutions listed there work. After not using my G2 keyboard for a while, I turned it on yesterday and all the LEDs lit up, with all the displays showing black boxes on the top row and blank on the bottom row. I restarted, tried unplugging everything, no difference. If I run the editor or OS updater (on a Mac) with the G2 plugged into USB, it's not found. I tried the startup combo mentioned here (performance mode, display mode, store buttons) but no effect. I also tried the startup combo listed in the manual for OS update (store, performance buttons), no change.
I've tried restarting a bunch and I usually get all LEDs on. Occasionally only some will be on, usually in a pattern (e.g. all of the encoders will have only certain of their ring LEDs on), but it doesn't seem to make any difference.
I also opened it up and tried reseating all the connectors. Nothing appeared out of place, and it made no difference. Nothing looks obviously broken.
It sounds a lot like issues other people have had, which were usually solved with the startup key combo. I don't know why it doesn't work for me. Is there any kind of hardware hard-reset? Any other ideas?
Is there someone to contact for service in the western USA?
