Posted: Tue Aug 14, 2018 12:07 am Post subject:
The Gate Out of Stage 1 went to trigger the Elements input on the switch, Gate Out of Stage 5 went to trigger the Braids input on the switch. I could have ran the clock into a divide by 4, but then I might have sync issues.
Elements wound up going into the CGS60 Stompbox Adaptor, purely for additional gain to ramp it up to Braids' level. The minor shimmer in it's chuffs was from a LFO into the Tone CV for the Blow exciter. (The moving tone in the exciter has an effect on the resonator section in turn.)
I tried running the final mix into the Serge Resonant EQ to get rid of that minor blip when going from Elements to Braids, but no luck. I also tried delaying the Gate Out of Stage 5 a little bit (run that into the Gate In of the Rampage, run the Falling output of Rampage into the switch trigger, play with the Rise time to get a gate delay), but that also didn't do much. I'll have to think about it. |
Joined: Nov 23, 2015 Posts: 1294 Location: Netherlands
Posted: Tue Aug 14, 2018 10:48 pm Post subject:
AlanP wrote: | Chuff sounds was Elements, chord sounds was Braids in three-saw mode with the other two saws tuned lower and lower again, then run through a reverb. |
Great sounds! _________________ my synth |
Posted: Fri Nov 09, 2018 9:25 pm Post subject:
Dad was around today, and I had some fun putting a patch together.
Changes roughly just after 4min into it.
Description: |
Filesize: |
306.33 KB |
Viewed: |
617 Time(s) |
Description: |
Download |
Filename: |
2018-11-10 dadfun.mp3 |
Filesize: |
7.88 MB |
Downloaded: |
1574 Time(s) |
Posted: Fri Nov 09, 2018 11:52 pm Post subject:
I can’t play it right now, one of the dogs starts barking when I play this...
Audio files: 278
Posted: Sun Nov 25, 2018 1:33 pm Post subject:
Some nice Awfulness there :-)
(and can't blame the dogs for recognizing the sounds) _________________ Jan
Audio files: 705
Posted: Fri Jun 26, 2020 4:13 pm Post subject:
208 Stored Program Sound Source with a basic krell patch, going through the MTM Reverb (wet/dry controlled by the 266 FRV.)
The 208 isn't completely finished, yet, still waiting on the spring tank.
Description: |
Filesize: |
379.82 KB |
Viewed: |
254 Time(s) |
Description: |
Download |
Filename: |
rec_20200627-104008_1.mp3 |
Filesize: |
17.65 MB |
Downloaded: |
866 Time(s) |
Posted: Wed Oct 28, 2020 12:38 am Post subject:
The last parts for my DIY 4MS Spectral Multiband Resonator turned up, soldering ensued, and playing around with it. This thing is insanely fun, and all I've done so far is run white noise into it, and plug various random voltages into it's control inputs!
The Dunno module (Buchla 266) is providing white noise, and clocked random voltages (which are going through comparators to provide triggers to rotate the bands either up or down in pitch), and the Triple Sloths module is providing CV to the Spread control, the Envelope CV In (I think), and the Resonance CV In. I'm not sure how much the last two were doing anything.
Lots of fun!
Description: |
Filesize: |
397.4 KB |
Viewed: |
224 Time(s) |
Description: |
Download |
Filename: |
2020-10-28 smr dunno sloth.mp3 |
Filesize: |
7.5 MB |
Downloaded: |
755 Time(s) |
Audio files: 278
Posted: Sat Oct 31, 2020 5:39 am Post subject:
AlanP wrote: | The last parts for my DIY 4MS [...] Lots of fun! |
Some nice sounds from that one! _________________ Jan
Audio files: 278
Posted: Sat Nov 20, 2021 12:36 pm Post subject:
Wild track :) _________________ Jan
