 Forum index » Online Music
AlanP's Awfulness
Page 3 of 3 [56 Posts]
Goto page: Previous 1, 2, 3
Audio files: 35
PostPosted: Tue Aug 14, 2018 12:07 am    Post subject: Reply with quote  Mark this post and the followings unread
The Gate Out of Stage 1 went to trigger the Elements input on the switch, Gate Out of Stage 5 went to trigger the Braids input on the switch. I could have ran the clock into a divide by 4, but then I might have sync issues.
Elements wound up going into the CGS60 Stompbox Adaptor, purely for additional gain to ramp it up to Braids' level. The minor shimmer in it's chuffs was from a LFO into the Tone CV for the Blow exciter. (The moving tone in the exciter has an effect on the resonator section in turn.)
I tried running the final mix into the Serge Resonant EQ to get rid of that minor blip when going from Elements to Braids, but no luck. I also tried delaying the Gate Out of Stage 5 a little bit (run that into the Gate In of the Rampage, run the Falling output of Rampage into the switch trigger, play with the Rise time to get a gate delay), but that also didn't do much. I'll have to think about it.
Audio files: 28
PostPosted: Tue Aug 14, 2018 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
AlanP wrote:
Chuff sounds was Elements, chord sounds was Braids in three-saw mode with the other two saws tuned lower and lower again, then run through a reverb.
Great sounds! Very Happy
my synth
Audio files: 35
PostPosted: Fri Nov 09, 2018 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dad was around today, and I had some fun putting a patch together.
Changes roughly just after 4min into it.
 Filesize:  306.33 KB
 Viewed:  208 Time(s)
2018-11-10 dadfun.mp3
 Filename:  2018-11-10 dadfun.mp3
 Filesize:  7.88 MB
 Downloaded:  552 Time(s)
Audio files: 28
PostPosted: Fri Nov 09, 2018 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can’t play it right now, one of the dogs starts barking when I play this...
Shocked
my synth
Audio files: 239
G2 patch files: 319
PostPosted: Sun Nov 25, 2018 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some nice Awfulness there :-)
(and can't blame the dogs for recognizing the sounds)
Audio files: 35
PostPosted: Tue May 14, 2019 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Had another play with the Appendage Touch Controller today. I'm not sure... but when I take my finger off the ribbon, sometimes the CV will drop very low, riiiight on the very end before the Gate goes low. In this patch, it was controlling Mutable Elements. (Pho, you really need to build this one!)
Erm, the background sequence is mainly to give me a beat, not for a melody to bounce riffs off.
I messed with the Contour knob on Elements a couple times.
2019-05-14 testtouch.mp3
 Filename:  2019-05-14 testtouch.mp3
 Filesize:  5.92 MB
 Downloaded:  282 Time(s)
