Joined: Nov 23, 2015 Posts: 1294 Location: Netherlands
Posted: Sun Nov 18, 2018 2:48 pm Post subject:
looking for schematic of a bandpass filter Subject description: simple to build and with a dual potmeter |
Help!
I'm looking for a bandpass filter where it is possible to shift the center frequency with one dual-potentiometer.
I know there must be some, but I cant fint them...
Power supply: +12volt, -12 volt
Center frequency: 300Hz - 3kHz _________________ my synth |
Audio files: 705
JovianPyx
Audio files: 224
Posted: Sun Nov 18, 2018 5:29 pm Post subject:
Why not a BP VCF like a state variable? Then you can have a pot (single) for Fc and another pot (also single) for Q. Then if you need to control it with voltages, you've got the inputs already there. _________________ FPGA, dsPIC and Fatman Synth Stuff
Posted: Mon Nov 19, 2018 12:41 am Post subject:
This might be just what I'm looking for...
Thanks! _________________ my synth |
gabbagabi
Joined: Nov 29, 2008 Posts: 652 Location: Berlin by n8
ixtern
Posted: Mon Nov 19, 2018 1:21 am Post subject:
Re: looking for schematic of a bandpass filter Subject description: simple to build and with a dual potmeter |
Grumble wrote: | Help!
Center frequency: 300Hz - 3kHz |
This times it is really hard to find a filter which is not voltage-controlled. And most of them are children of generic state-variable filters. Perhaps only guitarists are still using filters with potentiometers. Here is one of them (Anderton super tone control).
Instead of potentiometers people uses OTAs, FETs, DACs... to control filters by voltage or by Arduino
Below are some examples of such filters if you change your mind about way of control [FET VCF from gasboss ].
Simplest to build but hardest to modulate are the state variable filters where resistors (potentiometers) were replaced by multiplying DACs.
[from the AD8684 datasheet]
[from the AD7628 datasheet]
Description: |
Filesize: |
71.93 KB |
Viewed: |
399 Time(s) |
Description: |
Filesize: |
16.96 KB |
Viewed: |
310 Time(s) |
Description: |
Filesize: |
90.11 KB |
Viewed: |
328 Time(s) |
Description: |
Filesize: |
384.32 KB |
Viewed: |
329 Time(s) |
Description: |
Filesize: |
53.35 KB |
Viewed: |
335 Time(s) |
Posted: Mon Nov 19, 2018 5:34 am Post subject:
Thank you all for your input! _________________ my synth |
kaputtpanzer
Audio files: 15
Posted: Mon Nov 19, 2018 11:20 am Post subject:
This ist a very easy to build sallen key filter, that usually utilize a dual pot instead of the vactrols...
Project_2501
