tömbszelence
Posted: Wed Jan 23, 2019 3:36 am Post subject:
CGS78 UEG small "residual" voltage while Gate is high |
My CGS78 Utility Envelope Generator got trimmed for 2-3mV voltage offset on the output when there is no gate signal present.
But when there is a gate signal, even when i turn down the sustain pot all the way down to zero i got an "offset" of 200-300mV which is enough to keep my VCAs slightly open so i can't kill the output completely while i hold down a key or send a continous midi note on signal from my interface.
Can i trim this out somehow? I am open to add some additional parts.
On the topic of mods have anybody added an output buffer to this circuit? Since the circuit relies on the output signal to work when i connect the output to an attenuating input and turn it all the way down to zero (essentially connecting the UEG output to ground) it stops working, no LEDs or envelopes and it makes the whole thing less robust to use. |
Hubaswift
Posted: Fri Jan 25, 2019 11:06 pm Post subject:
An attenuator shouldn't ever short your input to ground. Say you have a pot, one end will go to your input, the other end to ground. the wiper in the center goes to your output so that the wiper is essentially scanning between the input and gnd. if you use say a 100k pot for your attenuator, the input will always have a resistance of 100k to ground. By the sounds of it you're using the wiper of your pot as the input of the attenuator when it should be the output. That aside, I have also built a CGS Utility EG. It's late for me now, but once I find some time during the weekend I'll look into your problem and check if mine exhibits the same flaw. |
tömbszelence
Posted: Sat Jan 26, 2019 3:55 am Post subject:
Hubaswift wrote: | An attenuator shouldn't ever short your input to ground. Say you have a pot, one end will go to your input, the other end to ground. the wiper in the center goes to your output so that the wiper is essentially scanning between the input and gnd. if you use say a 100k pot for your attenuator, the input will always have a resistance of 100k to ground. By the sounds of it you're using the wiper of your pot as the input of the attenuator when it should be the output. That aside, I have also built a CGS Utility EG. It's late for me now, but once I find some time during the weekend I'll look into your problem and check if mine exhibits the same flaw. |
Thanks for the answer, when i measured it i just connected a cable to the env/cv out and measured between the tip and of the sleeve cable.
You were right, i wired one of the CV pots wrong on that circuit which could mess with the UEG. (but since it had an initial CV level pot and also a trim for trimming CV i could trim out the error so i did not noticed what happened) |
tömbszelence
Posted: Mon Sep 23, 2019 10:45 pm Post subject:
Did you get around to measure it?
Yesterday i wanted to control the pitch of various oscillators with the UEG but this "bug" makes it impossile to keep in tune (even at zero sustain on the UEG when you release the keys and the gate goes low you can hear a drop in pitch because that residual 100-200mV goes to 0mV when the gate goes low) |
