BassMaster 85
Page 3 of 3 [61 Posts]
Goto page: Previous 1, 2, 3
JovianPyx
Audio files: 221
PostPosted: Mon Dec 17, 2018 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool!
How does the filter sound?
Time flies like a banana.
corruptio optimi pessima
Hammer
PostPosted: Mon Dec 17, 2018 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
It have very strange form of resonance. I think it will sound different with different MOSFETs.
MOSFET_SVF.mp3
 Filename:  MOSFET_SVF.mp3
 Filesize:  286.62 KB
 Downloaded:  249 Time(s)
JovianPyx
Audio files: 221
PostPosted: Mon Dec 17, 2018 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
MOSFETs (at least those in 4069ub and 4007) have an odd relationship between gate voltage and output. Using a 4007 or 4069 as a linear amplifier, gain is highest when the gate voltage is halfway between the rails and goes lower as the gate voltage approaches either rail. This can allow it to round out a triangle input, but I've no idea what harmonics are added/subtracted. The WASP filter uses 4069 as a distortion element which gives the WASP filter its crunch.
Hammer
PostPosted: Mon Dec 17, 2018 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I know it, and I like it)
I've use this circuit to test MOSFETs:
With 100k stereo pot it sounds better:
4069_SVF.mp3
 Filename:  4069_SVF.mp3
 Filesize:  281.78 KB
 Downloaded:  332 Time(s)
JovianPyx
Audio files: 221
PostPosted: Mon Dec 17, 2018 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow caps rated in mF - takes me way back. When I was a kid, I looked for TVs to scavenge on the curb on trash day. These were vacuum tube TVs. The caps were in mF or mmF which one doesn't see much these days.
Hammer
PostPosted: Wed Dec 19, 2018 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found this very interesting module: http://www.stgsoundlabs.com/products/digital_attenuators_mu.htm
This is digital pot based VCA. To get rid of clicks these guys make the switch of digital pot at the zero crossings of the input signal.
It remains now to understand whether the microprocessor has enough speed for zero crossing detection.
Or just to send a signal from the first ATtiny85 when PWM is 127.
Hammer
PostPosted: Thu Jan 10, 2019 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Vactrols lost during shipment Sad
But I got in the mail 100k digital potentiometers X9C104. 4069 SVF with this potentiometers sounds clean. But the resonance is too weak.. Will try with low pass gate.
BMS85_VX_Popcorn.mp3
 Filename:  BMS85_VX_Popcorn.mp3
 Filesize:  1.45 MB
 Downloaded:  245 Time(s)
Hammer
PostPosted: Sun Jan 13, 2019 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Still messing with flters...
But I've made some 5V digital VCA.
TL431 used as 2,5V comparator. In this curcuit envelope is exponentional. But if you will make inverting amp with digital pot. in feedback loop, envelope will be linear.
If you will use CD4069 as inverting amp with digital pot. in feedback loop, envelope will be also linear, but shape of signal may be distorted. For example, triangle wave will look like lines bended into arches.
Pot. can switch in non zero crossing point, and I don't know why, maybe because of TL431 is not the best decision. Maybe it's breadboard feature.
That's why I used the 470 pF capacitor. It removes the peaks from switching. Two oscillograms, with and without capacitor. Code also included.
5V digital VCA
 Filesize:  169.33 KB
 Viewed:  223 Time(s)
Without cap.
 Filesize:  76.2 KB
 Viewed:  198 Time(s)
With cap.
 Filesize:  99.23 KB
 Viewed:  197 Time(s)
Digital_VCA.zip
 Filename:  Digital_VCA.zip
 Filesize:  1.08 KB
 Downloaded:  212 Time(s)
Hammer
PostPosted: Mon Jan 21, 2019 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
And after one more month I got my vtl5c1 vactrols)))
And they are so slow... It's not necessary to use second ATTiny85 for PWM, i'ts sounds very intuitive if just change a length of note. Very clean and tasteful sound! I like it a lot!
BMS85_VX_vtl5c1.mp3
 Filename:  BMS85_VX_vtl5c1.mp3
 Filesize:  337.55 KB
 Downloaded:  236 Time(s)
Hammer
PostPosted: Thu Jan 31, 2019 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Now I can make single sided PCBs:
Hammer
PostPosted: Wed Feb 27, 2019 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Trying to etch a pcb. New circuit design and new code coming soon)
 Filesize:  880.03 KB
 Viewed:  163 Time(s)
 Filesize:  1015.44 KB
 Viewed:  165 Time(s)
