<on air> Modulator ESP Adventures In Sound
Digisound Voice Card
Page 1 of 1 [3 Posts]
micromusic
PostPosted: Sun Apr 28, 2019 12:36 am    Post subject: Digisound Voice Card
Subject description: Helllppp!!!!
Hi all
With the re-issue of most CEM chips I thought I would make a new Digisound voice card as its about the only module I dont have
http://www.digisound80.co.uk/digisound/modules/80-C9.htm is the link
It seems to work when first powered up but after about 30 seconds it starts to go quiet and distorted on the final output
I have done my usual checks and as normal can find no mistakes, that does not mean there is none !! I just cant find any
Its a self etched board and I have used all the listed components apart from the polycarbonate capacitors as I have substituted with polyester ones of the same value
Has anyone made one of these or has any other info on it?
Thanks
ixtern
PostPosted: Sun Apr 28, 2019 11:16 pm    Post subject: Re: Digisound Voice Card
micromusic wrote:
Hi all
First I would check supply source and lines. What are your voltage regulators? Small or large? Do they heating much? Check with your finger - if they are so hot you cannot touch they may go into current limiting mode, so the measured voltage may be OK but output current not.
I have similar case with other bad designed circuit: +5V voltage regulator was too small (78L05) to required current (about 100mA) and after few minutes was so hot it failed to output any current (although output voltage was still +5V).
micromusic
PostPosted: Wed May 01, 2019 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Thanks
Nothing gets hot and my 5 volt supply is 1 amp but I will check I am not loosing voltage anywhere
The problem seems to be around the fiter chip I just cant figure out where Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
