The VCO-555
Page 16 of 16 [393 Posts]
Goto page: Previous 1, 2, 3, ..., 14, 15, 16
Fabricio pecanha
PostPosted: Sat Aug 18, 2018 4:55 pm    Post subject: Tune problem vc 555
Subject description: Tune variation
Hello, I have a problem in my vco 555, I hope you get some help.
my vco was running well, but for some time he's running the tune alone. Has anyone had this problem?
Thank you for your help
PostPosted: Sat Aug 18, 2018 5:41 pm    Post subject: Re: Tune problem vc 555
Hi Fabricio. I'm not sure I understand what you mean by running the tune alone?
Dozemuisc
PostPosted: Thu Jul 11, 2019 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello!!
We are building a biiig4voice-polyphonic semi-modular synth with 8 Thomas Henry 555, 3 quadruple Druid ADSRS, 2 quadruple MFOS VCOs, 1 quadruple Yusynth MiniMoog VCF and one 5tuple LFO. All of wich with global controls and 4-channel patch cables.
For now it's all working well exept i have a problem with two TH555.
They can only go down to around 5Hz while all the others go down to 1Hz...
It's not the V8 Trimmer as the value is the same for all the VCO's after it...
I debugged them for hours and measured some values and i don't understand.
Here is the schematic with measures. I already tried to change the IC's (in green).
Could you help me?
Doze
PostPosted: Thu Jul 11, 2019 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a wild guess, but what about swapping the 555s with ones from the 'working' modules? Would this make a difference?
Tech Budday at Random*Source
PostPosted: Thu Jul 11, 2019 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
additionally, check C4.
Dozemuisc
PostPosted: Thu Jul 11, 2019 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
Thanks for the answer Smile
I already tried swapping 555s it doesn't change anything.
I tought also that it could be C4 but i have exactly the same problem on 2 VCO's that go down to the same frequency... And it is good quality MICA's at 8 euros each... If i don't find answers i'll try to put another condenser but I don't have anymore left!
PostPosted: Thu Jul 11, 2019 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
When mentioned C4 I did not think of the general characteristics of the type used, but more of the absolute value.
PostPosted: Thu Jul 11, 2019 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
you could even try to swap the OTAs. IIRC the LM13700 have huge tolerances in behaviour.
Dozemuisc
PostPosted: Thu Jul 11, 2019 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Swapped the LM13700, didn't work, measured AND swapped C4 (as i already unsoldered it to measure it), it has the same value and that didn't work as well.
The bastard still oscillates to high!
PostPosted: Thu Jul 11, 2019 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm...
PostPosted: Thu Jul 11, 2019 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you verified that pin 1 of IC3a actually appears to track the CV inputs from the coarse and fine inputs? And is "sane" ?
ixtern
PostPosted: Fri Jul 12, 2019 2:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Dozemuisc wrote:
Hello!!
Could you help me?
Doze
There is yet one rare but posibble reason for VCO misbehavior - fake TL074. I have encountered bunch of such ICs bought from local supplier. They were all shiny new with TI manufacturer marks but all have big input currents - an order of nA instead of pA. Otherwise they behaved as normal op amps, what suggests they were rebadged bipolar op amps.
Try to swap TL074 for trusted ones. Maybe this helps.
Dozemuisc
PostPosted: Sat Jul 13, 2019 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
What do you mean if IC3 is sane? Why wouldn't it track well? You mean like bad soldering? Thanks Smile
Ixtern I've already swapped all the IC's including the TL74 for those of the sane VCO's and it stays the same.
It's really a mystery.
PostPosted: Sat Jul 13, 2019 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Re-read:
PostPosted: Sat Jul 13, 2019 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
elmegil wrote:
Re-read:
If all your TL074's are from the same supplier, swapping one won't do anything.
Dozemuisc
PostPosted: Sun Jul 14, 2019 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah sure they are not fake, they come from Mouser and they work in all the other TH555's.
ixtern
PostPosted: Sun Jul 14, 2019 11:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Then maybe 2N3906 are not paired and they have different enough characteristics to create bias limiting lower frequency? Have you tried to check their Vbe and beta?
Dozemuisc
PostPosted: Mon Jul 15, 2019 1:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I matched them for VBe at 1mV using MFOS circuit, and i don't know how to measure beta.
