Airell
Posted: Thu Dec 12, 2019 5:58 am Post subject:
New Nomad build works natively (with Java) on macOS |
Hello,
For anyone interested, I have made a new build of the Nomad editor for the NM classic. Jan aka Blue Hell helped with tackling issues and testing on macOS.
You will need Java 1.8 installed and I have tested it on macOS 10.14 (Mojave) in a Virtual machine. Jan tested on a physical machine. Catalina might work, but we have no hardware available where MIDI hardware drivers are supported.
Get Nomad 0.4.20191212 here: https://oracle48.nl/Nomad/index.html
No new functionality has been added, just fixes and support for MIDI on newer macOS versions.
Regards, Airell. |
Joined: Apr 03, 2004 Posts: 24083 Location: The Netherlands, Enschede
Audio files: 278
Posted: Thu Dec 12, 2019 6:29 am Post subject:
Thanks Ian, I'm happy with it _________________ Jan
Airell
Posted: Thu Dec 19, 2019 12:34 am Post subject:
I have updated to version 0.4.20191218 .
This adds starting the Nomad application without opening the package file and solved an issue with opening and saving patches.
It assumes the default location of where java is installed.
I'm aware of 'gatekeeper' and I'm not a registered developer so you will get the 'unknown source/developer message'.
Download and please also read the instructions at: https://oracle48.nl/Nomad/index.html
Airell. |
KarmanHardon
Posted: Wed Jan 15, 2020 5:22 pm Post subject:
Oh wow what a nice way for the 'ol G1 to kick the new decade off!!
I can't wait to try this! The midi issues always made me go back to the original editor...
Thank you for keep it alive!!!
This synth has completely rocked my world and I never really suffered from GAS after getting it 10 years ago.
All the best! |
toutvabien
Joined: May 20, 2017 Posts: 1 Location: City Bell, Argentina
Posted: Sun Apr 12, 2020 4:54 pm Post subject:
Micromodular, connected on MacOS 10.15.4, using OpenJDK 8u242!
Thank you!!!
chapelier fou
Posted: Tue Apr 14, 2020 2:46 am Post subject:
Thanks a lot ! Testing ASAP |
chapelier fou
Posted: Tue Apr 14, 2020 10:46 am Post subject:
Is there a way to upload a bank from the micromodular to the computer ?
Otherwise, seems to work fine here ! |
puristin
Posted: Sat May 02, 2020 3:20 pm Post subject:
Any idea how to get the editor working under Ubuntu? Both windows or macOS setups do not work as such. However, I suspect it should be relatively easy to launch this also under Linux with the correct launch script. |
pmike
Posted: Tue Jun 01, 2021 12:03 am Post subject:
The app is launching but I don't have the midi configuration window, and the properties screen lists : Info, Settings and Notes. But not Connection Settings.
Any idea ? |
