Nitro
Posted: Mon Mar 30, 2020 4:22 am Post subject:
Blofeld sound problem Subject description: Blofeld, no sound at all |
So, i discovered that my Blofeld desktop model does not give any sound out, any of the plugs, so apparently the transistor fault is the cause of this, i guess.
Fixing it seems pretty easy, at least some instructions what i have found, from the net, but the problem is, my Blofeld has different kind of pcb in it, what is in these instructions. I think it is newer model.
Does anyone know or have repaired this kind of pcb with the same sound problem? Last edited by Nitro on Mon Mar 30, 2020 11:56 am; edited 1 time in total |
Nitro
Nitro
Posted: Sat Apr 18, 2020 8:06 am Post subject:
Problem solved, how to fix the faulty resistor |
So i got mine fixed after hard research and work! I post the solution what i used, if it would help someone, who is struggling with same problem.
I am not expert and if you follow these instructions, you do it with your own responsibility. This is just how i did get my machine back working again.
Below is picture of the newer pcb where i have marked the faulty resistor place with red circle. Some reason, Waldorf decided to put the part in more difficult place to replaced it, what it was in the older version, where it was fairly easy to fix. Between two capacitors, which are quite close to that resistor, so desoldering and new part soldering can be very tricky!
Description: |
Filesize: |
3.95 MB |
Viewed: |
464 Time(s) |
Nitro
Nitro
