 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
New Nomad build works natively (with Java) on macOS
Page 1 of 1 [8 Posts]
Airell
PostPosted: Thu Dec 12, 2019 5:58 am    Post subject:  New Nomad build works natively (with Java) on macOS Reply with quote  Mark this post and the followings unread
Hello,
For anyone interested, I have made a new build of the Nomad editor for the NM classic. Jan aka Blue Hell helped with tackling issues and testing on macOS.
You will need Java 1.8 installed and I have tested it on macOS 10.14 (Mojave) in a Virtual machine. Jan tested on a physical machine. Catalina might work, but we have no hardware available where MIDI hardware drivers are supported.
Get Nomad 0.4.20191212 here: https://oracle48.nl/Nomad/index.html
No new functionality has been added, just fixes and support for MIDI on newer macOS versions.
Regards, Airell.
Audio files: 251
PostPosted: Thu Dec 12, 2019 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ian, I'm happy with it Cool
Airell
PostPosted: Thu Dec 19, 2019 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I have updated to version 0.4.20191218 .
This adds starting the Nomad application without opening the package file and solved an issue with opening and saving patches.
It assumes the default location of where java is installed.
I'm aware of 'gatekeeper' and I'm not a registered developer so you will get the 'unknown source/developer message'.
Download and please also read the instructions at: https://oracle48.nl/Nomad/index.html
Airell.
KarmanHardon
PostPosted: Wed Jan 15, 2020 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh wow what a nice way for the 'ol G1 to kick the new decade off!!
I can't wait to try this! The midi issues always made me go back to the original editor...
Thank you for keep it alive!!!
This synth has completely rocked my world and I never really suffered from GAS after getting it 10 years ago.
All the best!
toutvabien
PostPosted: Sun Apr 12, 2020 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Micromodular, connected on MacOS 10.15.4, using OpenJDK 8u242!
Thank you!!!
cheers dancing
chapelier fou
PostPosted: Tue Apr 14, 2020 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot ! Testing ASAP
chapelier fou
PostPosted: Tue Apr 14, 2020 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there a way to upload a bank from the micromodular to the computer ?
Otherwise, seems to work fine here !
puristin
PostPosted: Sat May 02, 2020 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any idea how to get the editor working under Ubuntu? Both windows or macOS setups do not work as such. However, I suspect it should be relatively easy to launch this also under Linux with the correct launch script.
