 Forum index » electro-music.com
EM website updates
Page 1 of 2 [28 Posts]
Audio files: 645
PostPosted: Fri May 22, 2020 9:59 am    Post subject: EM website updates
Subject description: suggestions
I think there was already a thread like this before but I can't find it, maybe it was only discussed in the chatroom, but here goes.
With the addition of videostreaming in the works I think it might be a good time to update some other sections as well.
Overall I like the format and I don't think the site itself needs any big changes. One of the main things I've always appreciated
about it is that it just works very well (one of the few sites I have always been able to use with Firefox 3.6) and it doesn't have
a lot of unnecessary distracting nonsense going on. Visually all the different hues of blue go together well and I do find it
pleasing to the eyes. Maybe a dark theme could be nice too but that's not really important. Now that I am writing this post I do
notice that the buttons for the BBCode are spread apart, it would look nicer without any space between them but I have no idea
how much can be customized.
a HTTPS version of the site would be very welcome which is already being discussed here.
The frontpage, where new visitors will probably end up sooner or later could use some updates:
- remove or at least update the store section, the most recent item is from 2006 (and those are the "New products")
I don't even know how much is actually still availble besides the AmbiophonicDSP plugin which has a seperate section anyway (please remove the text "News 27/Oct/09" above it) .
- News and other sections are also very outdated, basically the whole frontpage is.
- The welcome text might need a little update too (or at least remove the text "electro-music is new music; still undefined; happening all over our planet." There is also no mention of the chatroom and maybe streaming events deserve a mention too.
- Some links in the information section take you to the store which I guess is where the info is stored but it is a bit annoying if I click on a link and my mouse is now hovering over a different section.
- remove empty space from the radio schedule/playlist.
- Maybe a section with the most recent forum posts could be added to the front page too since that is the most active part of EM.
Having mentioned that I like how the site looks I do feel that things sometimes seem to get a bit lost being plain text. For example the
text "Live streaming at radio.electro-music.com" is a bit floathing around and might look better if it is part of the MOTD below it.
Also an
embedded player for radio 1 might be nice there (is it possible to make a player with a drop down menu for the other channels ?)
The Links section:
- haven't really tested this but knowing the internet there are probably a lot of dead links,. I actually never visited it before.
The wiki:
- can the logo be changed so that it is the same as the rest of the site ?
- I just updated a couple of the radio sections but there is probably some more stuff that needs updating.
- overall it looks good, thanks jan! (although I do find the formatting rather difficult)
Media:
- maybe split it in sections per year as it is quite a lot to load at once. (but please don't do the infinite scrolling thing!)
I am not sure what section I landed on a while ago but it was full of spelling errors. So maybe it's good that I can't find it now.
edit: might have been this one: http://electro-music.com/affiliates.php
these are mere suggestions and I will be adding more if I think of something.
Audio files: 645
PostPosted: Fri May 22, 2020 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
how much of this is still valid ? http://electro-music.com/wiki/pmwiki.php?n=Site.Chatroom
Audio files: 645
PostPosted: Fri May 22, 2020 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
this one also needs to be updated: http://electro-music.com/forum/mycalendar.php
Audio files: 249
G2 patch files: 319
PostPosted: Fri May 22, 2020 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fixed it - more or less.
Removed the Jez & Rob thing
Check .. it's not quite what I would want it to be, code wise, but seems to do the job.
Ok .. integrated it a bit more ...
the text: host / artis .. show ... at your time
should only show when there actually is a show ... I don't have the guts tho to fix that .. I think .. I'll look at it though. Ok, that seems fixed too now.
The wiki:
The logo .. I need a logo with transparency or it will not work ... the standard logo has a white background which sucks on the wiki ... when someone would be so kind to have the patience to make it into a transparent background one (preferably with a tiny bit of drop shadow ...) .. I'd change it. Anyway .. I've just found out again why I made a new one for it ;-)
I've changed the main radio page on the wiki to have all current stations.
Audio files: 645
PostPosted: Fri May 22, 2020 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks jan thumleft
Audio files: 29
PostPosted: Fri May 22, 2020 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Would be great if youtube can be embedded 😳
my synth
Audio files: 249
G2 patch files: 319
PostPosted: Fri May 22, 2020 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can be ... when you right click on a youtube movie you can get some code to paste into a post (use copy embed code).
Edit: removed example.
Audio files: 29
PostPosted: Fri May 22, 2020 9:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
It can be ... when you right click on a youtube movie you can get some code to paste into a post (use copy embed code)
Thanks, didn’t know that...
my synth
Audio files: 249
G2 patch files: 319
PostPosted: Sat May 23, 2020 6:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I've moved a bit of clutter to my top reply here .. to have it all in one place.
Audio files: 645
PostPosted: Sat May 23, 2020 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
take your pick.
note that this has the same dimensions as the original logo which is 430x42, the wiki logo was 430x45 (also it's a png instead of a gif)
 Filesize:  6.55 KB
 Viewed:  269 Time(s)
 Filesize:  9.68 KB
 Viewed:  269 Time(s)
 Filesize:  9.63 KB
 Viewed:  269 Time(s)
Audio files: 645
PostPosted: Sat May 23, 2020 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
oh you did it on the radio page, I meant the front page, that also does look better though Very Happy
hmm, yes and no. it is kind of what I had in mind but it is a bit too intrusive now. Does look a bit better if you use the lighter shade of blue #DEE3E7
I think I am going to mess around a bit with it in photoshop.
Audio files: 249
G2 patch files: 319
PostPosted: Sat May 23, 2020 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
oooh Shocked we have a front page Exclamation heh .. I never go there.
Hmm ... I can not easily fix it there ... all I can do is make the boxes smaller .. but they are fixed size ... so they will get a scrollbar when it won't fit ... anyway .. did that ... it is a forum post being displayed there as an article .. and the amount of trickery allowed in a forum post is very limited .. maybe some clever CSS, but can't come up with anything yet.
And thanks for the logos! will put one in Cool
Audio files: 645
PostPosted: Sat May 23, 2020 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah I don't visit the fornt page myself either and it is the most outdated part.
The radio schedule looks much better now, and I actually like the scrollbar. Thanks!
messed around in photoshop a bit with the MOTD, here's a suggestion
(I see you are working on it too)
 Filesize:  129.13 KB
 Viewed:  2 Time(s)
 Filesize:  129.13 KB
 Viewed:  3 Time(s)
Audio files: 249
G2 patch files: 319
PostPosted: Sat May 23, 2020 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah .. issue is .. colors need to work on the radio page as well, so made it even lighter, but it has an 'inverted' effect now on the radio page ... will mess a bit with the layout too now ...
Audio files: 645
PostPosted: Sat May 23, 2020 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
here's another one, I will check how it looks on the radio page too.
edit: also why does the radio page have a different bakcground color ? Laughing
 Filesize:  129.61 KB
 Viewed:  2 Time(s)
Audio files: 249
G2 patch files: 319
PostPosted: Sat May 23, 2020 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
because Evil or Very Mad
Ok .. I'm done toying with it for now .. any better now?
Audio files: 645
PostPosted: Sat May 23, 2020 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
a lot better, thanks Smile
I tried a small darker border around it which also works on both pages but I might like your version better.
 Filesize:  129.7 KB
 Viewed:  3 Time(s)
Audio files: 249
G2 patch files: 319
PostPosted: Sat May 23, 2020 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Edit 2: there are two radio logos at the bottom that are ... hmm .. could use some work ... but erm .. I'm not so good with image editors .. I do have sort of sources for the other five .. if needed .. so .. if someone could have a go at those please?
heh, I actually started on trying that. I can't seem to find the exact font jake used but probably have something similar.
Can redo all of them for consistency which isn't that much work once I have it setup. If you have some source files that would be great.
I could also try a completely different design of course.
oh shit, I pressed edit instead of quote Embarassed
Audio files: 645
PostPosted: Sat May 23, 2020 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
a reply just so you know I tried to reply.
enjoy your dinner, I'll have more tea
Audio files: 249
G2 patch files: 319
PostPosted: Sat May 23, 2020 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oooh .. nice mess pho :p
Sources, I'll send you a PM with what I got from Jake and how I messed with it a bit.
Edit: have sent.
Audio files: 645
PostPosted: Sat May 23, 2020 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Radio6 and Radio7 logos. Wasn't sure what color to pick for Chez Mosc but this works. I can try something else if you have suggestions.
nice speaker Very Happy
 Filesize:  10.42 KB
 Viewed:  151 Time(s)
 Filesize:  8.7 KB
 Viewed:  151 Time(s)
Audio files: 249
G2 patch files: 319
PostPosted: Sat May 23, 2020 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Djeez .. that was fast .. will put 'm in, they look great!
And yeah .. fiddling a bit with the details .. done fiddling now I think ...
Audio files: 645
PostPosted: Sat May 23, 2020 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
another suggestion but front page related so that's howards buisness.
move or copy the affiliate partners text that's at the bottom to the Contribute To Our Site section which also has the paypal link.
The affiliates page should be updated first though. Might also want to add Patreon as that's what the kids are into these days Laughing
I've never looked into it myself so I don't exactly know how it works and what the terms and conditions are.
Audio files: 645
PostPosted: Sat May 23, 2020 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
here's an avatar for the noodleradio in case you want one.
 Filesize:  29.64 KB
 Viewed:  131 Time(s)
 Filesize:  31.94 KB
 Viewed:  131 Time(s)
Audio files: 249
G2 patch files: 319
PostPosted: Sat May 23, 2020 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice ones PHOBoS, need to think about how to get one in .. its a bit of a non standard radio ... had been looking at that empty space myself already too ...
