3phase
G2 patch files: 141
Jason
Joined: Aug 12, 2004 Posts: 466 Location: Los Angeles, CA. USA
Posted: Fri Jul 29, 2005 8:33 pm Post subject:
Would you mind posting some documentation explaining what this patch is used for 3phase? It's cool to have info with the patches.
But I dont know what this is used for and am interested.
Thanks |
3phase
G2 patch files: 141
Posted: Sat Jul 30, 2005 4:42 am Post subject:
Jason wrote: | Would you mind posting some documentation explaining what this patch is used for 3phase? It's cool to have info with the patches.
Thanks |
I requested that i sometimes need a compare module that only triggers when having the same value..not the same value and bigger, as like in the compare/value module.
Somebody stated that the value switch is good for that but it dont reacts on bipolar inputs..what can be easily fixed with a value converter module in the input.. In this version with a switch..but to save dsp the switch can be removed in the actual patch.
I had used the value switches a couple of times in the past but sometimes run into problems so still felt the need for a dedicated module.. The kind of problems that happend when very fast parameterchanges with continous controlers or audio like signals made the switch not react properly...
The Quantizer module in the input is sorting theese issues.
It appears in 80% of the cases not necessary but in some cases where you dont get acurate triggering in a logical configurations these quantizer in the input cures quite a lot of little hazzles...
As it name says its quantizing its input values to even numbers...
The nord modular system is able to produce values inbetween...
Quite a few values inbetween actually.
Otherwise you wouldnt hear a clean pitch sweep on an oscillator when adjusting a constant module connected to a pitch mod input..
So even when the Module only can send 128 full number values the control signal itself knows states where you have subdivisions..
That can cause a situation where the trigger state with an value switch just becomes too short to be propperly read out.
For examples when the trigger value is for and the inputvalue is going
3.85>3.97>4.00>4.14> 4.6... with the quantizer the values will look like
3.00>>>>>4.00>>>>5.0...
This makes the time the switch has to process its values a bit longer and therefore makes it to react more acurate in certain situations.
In most aplications where clean controlsignals can be applied the quantizer can be removed.
I usually like to have buildingblocks that are on the safe side.
It also creats easy options for reductions when you have to slim a patch.
You can safe quite a few % of this building block in most applikations but as soon you try to trigger with audiorate sources you might need the quantized input...
OK? |
Rob
Joined: Mar 29, 2004 Posts: 580 Location: The Hague/Netherlands/EC
G2 patch files: 109
Jason
Posted: Tue Aug 02, 2005 6:33 pm Post subject:
Thank You for the nice info, I appreciate it.
I need to study it more, just wanted to say thanks for now.
This modular stuff sure is fun but can be challenging for those of us
new to this amazing modular world! |
Joined: Jan 31, 2003 Posts: 18197 Location: Durham, NC
Audio files: 212
Posted: Tue Aug 02, 2005 6:39 pm Post subject:
Jason wrote: | This modular stuff sure is fun but can be challenging for those of us new to this amazing modular world! |
Ha ha... It's challenging for everyone, including wizards like Rob. Why do you think he does it? _________________ --Howard
my music and other stuff |
