Wacky, Zany, Weird (and possibly Odd) Sound Maker Project
Page 2 of 9 [206 Posts]
Goto page: Previous 1, 2, 3, 4, ..., 7, 8, 9 Next
adhdboy
PostPosted: Sat Jun 04, 2005 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
OK. I'll check it out and post the results as soon as possible.
There 10 kinds of people in this world that understand binary those that do and those that don't.
ladislaobiro
PostPosted: Tue Jun 07, 2005 2:34 am    Post subject: Reply with quote  Mark this post and the followings unread
While waiting for a (hopefully positive) response from Ray, anyone etched a board and tested the circuit? were you guys brave enough? Smile
ladislao
Wild Zebra
PostPosted: Tue Jun 07, 2005 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry not yet. I'm so broke I'm trying to scrape enough money to order
switches and jacks for the soundlab I've been slowly but surely piecing together. As soon as I get get a chance, but hopefully some will soon.
"your stripes are killer bro"
ladislaobiro
PostPosted: Wed Jun 08, 2005 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Wild Zebra wrote:
Sorry not yet.
no problem Wild Zebra...
in the next few days I will etch myself a PCB based on my layout so I'll definitely understand if my board really works or not...
I will keep you updated.
bye
ladislao
adhdboy
PostPosted: Thu Jun 09, 2005 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi All
I thought I would have time to look over Lorenzo's board layout but I can see that I'm not. Too many things going on to do it so sorry but I have to bow out.
If someone wants to do it I suggest printing the schematic and then printing the layout and just verifying each and every connection one at a time. Mark a segment on the schematic with a highlighter and then see if the segment exists in the PC layout and is not touching anything else. Typically after I make a layout I make a board myself to see if its correct so that is another alternative.
Ray
ladislaobiro
PostPosted: Fri Jun 10, 2005 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
adhdboy wrote:
Hi All
no problem Ray, I perfectly understand what you say 'cause I'm facing the same situation... I designed my layout more than a week ago and didn't find the time to etch my own board yet due to many other things to do...
It seems that this weekend I will have some time to spend on the WSG, so I will probably be able to build and test the circuit.
That's exactly what I've done this morning for the 10th time, and it looks like the layout is definitely correct.
I will post the results of my tests here as soon as possible.
bye
ladislao
ladislaobiro
PostPosted: Fri Jun 24, 2005 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
yesterday I finally finished my WSG, and it works just fine... no doubt about the PCB layout: it is definitely correct...
I will post a picture of my circuit in a few hours...
bye
ladislao
ladislaobiro
PostPosted: Fri Jun 24, 2005 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Here we go... here's a couple of pictures of my WSG...
next step will be a search for a nice box (maybe a custom made one)...
bye
ladislao
 Filesize:  88.32 KB
 Viewed:  15209 Time(s)
Wild Zebra
PostPosted: Fri Jun 24, 2005 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Sweet Cool. Just finished my soundlab sortof(I'll be making a post) so that'll be around the bend. It looks real nice, all onboard nice and tidy.
ladislaobiro
PostPosted: Fri Jun 24, 2005 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Zebra for your comments, and good luck with your sound lab!!!
ladislao
adhdboy
PostPosted: Fri Jun 24, 2005 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
ladislao that is a really nice job! Everything you build is always really precise and well thought out. Thanks for sharing it with the world too.
Cheers and Nicely Done! Very Happy
Ray
ladislaobiro
PostPosted: Sun Jun 26, 2005 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ray, it's nice to see you appreciate my job... but I think the one that must be thanked (does this work exist?!?! well, I think you guys understand what I mean) is you for these great projects you make...
thanks again!!! Smile
ladislao
fluxmonkey
PostPosted: Thu Jul 14, 2005 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey, i finished putting together my wzw(apo) project last night, using ladislao's pcb layout. really great sounds, the filter is particularly spectacular. will head down to electronic surplus this weekend for the requisite selection of unmatched 1960's knobs. thanks both ray and ladislao!
hardest part was resizing the gif... working on a mac, i had to shrink it 18.5% or something odd like that...
bbob
ladislaobiro
PostPosted: Thu Jul 14, 2005 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are welcome bbob!!! I'm happy that it worked out fine...
Sorry for the odd dimensions of my GIF, but in order to get a good image quality when reducing the GIF, I had to drew it as big as possible with no care about the scaling percentage...
bye and good knobbing!
ladislao
Wild Zebra
PostPosted: Fri Jul 29, 2005 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is an PDF. of the WSG. just make sure the Page Scaling is set at none. Make sure you doulble check the size with an IC and let me
know if its OK
wsg.pdf
 Filename:  wsg.pdf
 Filesize:  15.73 KB
 Downloaded:  423 Time(s)
Wild Zebra
PostPosted: Wed Aug 03, 2005 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I put this sucker together last night. Sounds pretty WACKY. So the PDF is confirmed. I didn't have enough 1M pots so I used a 100k on the filter it sounds fine, but I'll have to change it later. Only thing I'm wondering is upon listen and comparing to some sound samples I'm not getting that Sqaurewavy on off type modulation or sound. Not sure if my
"zaniness amount" 100k pot is working. I'll have to change it tonight and post results.
So anyway thanks a million ladislaobiro for doing that layout.
opg
PostPosted: Wed Aug 10, 2005 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
This will be my first sound lab project! I've been looking around for a good one to start with, and I'd love to make the minisynth at the Music From Outer Space Site, but I thought I should start with something smaller. Thanks for posting all the info! I'll put up a picture of mine when I finish.
Wild Zebra
PostPosted: Wed Aug 10, 2005 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
allright let us now how it goes. The layout absolutely works. So have fun.
opg
PostPosted: Wed Aug 10, 2005 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, do you have any advice for an easy way to make the PCB? I would really like to avoid swimming in those "dangerous chemicals."
PostPosted: Thu Aug 11, 2005 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope- it's smelly chemicals all the way :) Unless you make one up on stripboard- then there are no chemicals involved.
http://electro-music.com/forum/topic-7074.html
(the link for the stripboard layout)
Pehr
PostPosted: Tue Aug 23, 2005 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Yay! Very Happy I just finished my Black Box (Wacky, Zany, Weird (and possibly Odd) Sound Maker) and it sure makes weird sounds! Cool
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Wild Zebra
PostPosted: Tue Aug 23, 2005 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Sweet, Looks good. What layout did you use? or did you do your own.
I just finished one about a week ago. I'm fixing to put one of those, a light theremin, and a little mini amp into on box for a little noise maker.
Give to a friend for Christmas.
Pehr
PostPosted: Tue Aug 23, 2005 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I used Lorenzo's with a few modifications ^_^
YouTube channel
flickr photostream
Wild Zebra
PostPosted: Tue Aug 23, 2005 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Same here. What mods? Anything interesting?
Pehr
PostPosted: Tue Aug 23, 2005 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
no nothing special... just changed the PCB layout so my SPST swithches fitted into it.
Heres a sample of how it sounds... Rolling Eyes
YouTube channel
flickr photostream
