Jason
Joined: Aug 12, 2004 Posts: 466 Location: Los Angeles, CA. USA
Posted: Mon Aug 15, 2005 10:03 am Post subject:
Drum & Bass patches |
I am currently working on a Drum and Bass tune that I am really enjoying. Now I just need some huge bass line or sometimes referred to as 'roller' patches I guess though I am not sure how specific that term is.
Often in this context I hear sometimes some sorts of pitch modulation over time on the envelopes or something too. I havent had much luck creating my own though. Anyone have any time and care to post a simple example perhaps? I have found a few patches in the archive that were just more of the distorted pad type and not as much on the deep bass side. Or if anyone has ideas of where to start that would be cool too! Thanks |
Joined: Jan 31, 2003 Posts: 18198 Location: Durham, NC
Audio files: 213
Posted: Mon Aug 15, 2005 10:16 am Post subject:
What about the factory patch SlowBass FM4
It's 1:22 on my machine. _________________ --Howard
my music and other stuff |
Posted: Mon Aug 15, 2005 10:41 am Post subject:
I think the basic "roller" sound is based on long notes with a big envelope on the filter cut-off but also a BPM synced lfo to the cutoff.
The envelope's attack should probably rise about as fast as the AMP envelope, decay fairly quickly for a brief (16th note or so) bright start followed by the pulsing modulalation of the lfo that slowly die out thanks to the filter envelope's decay.
Further evolution inside of the sound can be acomplished by more envelopes set do modulate parameters like the relative volume of oscilators.
The thing that probably needs most care is the syncing of the LFO and how it relates to other rithmic elements in the song. Setting it to the same timing as yout highhats gets a more militant feel while offsetting it to go inbetweent he hats maight make for a more bouncy vibe. Of cource that can be varied over the cource of the piece and forms inbetween might create a lot of drive. The relation between the Attcak and decay settings of the amplitude and filter envelopes on one hand and the exact shape and period of the lfo will also be quite important. LFO sync is absolutely nesicary but you might want to go as far as mapping some CC to the phse offset for musical developments. _________________ Kassen |
Jason
Posted: Mon Aug 15, 2005 11:04 am Post subject:
Thanks for all the info , yes mosc that is a good patch to start with thanks, just need to add some pitch mod to it maybe not sure.
Well Kassen thanks for all that info, though I am looking more for a pure sine bass tone that doesnt depend on sync in terms of lfo in this example of a very simplified 'roller', but this is also very good info you give here thanks, and I totally have to experiment with that too. I should have been more specific, but there are really many DnB tones I am after not just this. There are so many aspects of DnB I have always loved but it is hard for me to create my own original sounds at times. |
Jason
Posted: Mon Aug 15, 2005 11:10 am Post subject:
hmmm but maybe the LFO sync is what is needed for the pitching of the sine tone? Or you could use the envelopes to do this too? For that initial pitch from high to low? Not sure.... Must experiment more. Thanks again! |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Mon Aug 15, 2005 4:46 pm Post subject:
Try 2 saws detuned a fair amount, maybe with a little bit of fm for that beating effect. Filter this down a fair way with a little or no rez and then saturate this to taste. Now, after distortion take out the sub frequencies completely with a 48db highpass set to 70 or 80. Then you want a dry sine wave tuned down into the sub frequencies, to mix in with the distorted sound right before output. The reason for this is to keep the bottom end clean, but still with the character of the rest. It's hard to get the balance of these right, so play around a bit. I know Kassen doesn't like the idea of a big subby bottom end , but if it's going to be played in a club with a decent system, you'll definitely be able to feel/hear the subs and you don't want your track to be missing these, especially with drum and bass, as it will sound alot weaker than the other tracks being played. Drum and bass is allll about the bass.
Also try adding in a couple more filters (band or highpass) with their own distortion and envelope sweeps. LFO's can be nice... maybe turn kbtracking on 100% or 75% to keep that beating effect accurate to the pitch. Also, depending on what kind of sound you want, you don't necessarily have to sync the lfo to tempo. I find it syncing looses any kind of groove you could have gotten from the lfo. Play with the frequency until you find something that works well the bassline itself, that makes it drive harder or work better with the drums. You can also try hooking up the keyboard module's gate to the reset of the lfo every key stroke to maintain some kind of predictability when you're still playing around with it.
Hope some of this is useful... |
Jason
Posted: Mon Aug 15, 2005 9:00 pm Post subject:
wow afro88, that is very helpful!
Here is my first attempt. Keep in mind modular stuff is very new to me so my patching may not be logical etc... lol
The saw detune trick is really important for some of these patches ,
I think I was mistaking this sound
for pulse width modulation though surely that is used at times as well.
This patch seems like an ok start though it still is a ways off I think.
Anyway , if you could give me some feedback on this patch I would really appreciate it! Thanks folks |
General Elektrick
Joined: Apr 06, 2004 Posts: 254 Location: Berlin/Germany
Afro88
Audio files: 12
G2 patch files: 79
Jason
Posted: Tue Aug 16, 2005 7:29 pm Post subject:
Afro88 thanks again so much for the tips and this nice patch too, its awesome! It is really a great deal of help. General Elektrick , I like your patch alot too. It sure would be cool if people posted some more DnB patches here. If & when I make more I will post some. Some drums too would be nice. I think that the G2 should be able to make some nice snares too for DnB. |
General Elektrick
Posted: Wed Aug 17, 2005 9:35 am Post subject:
Nice one,
Afro
I like it ! _________________ Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage. |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Thu Aug 18, 2005 3:31 am Post subject:
Ouch! Sorry, I uploaded the wrong version - the sine wave should be tuned to -36. The post is updated above with the fixed version |
General Elektrick
Posted: Thu Aug 18, 2005 6:09 am Post subject:
Hey afro,
thats even more D&B Style _________________ Best,
General Elektrick
BSE|Milan
Joined: Aug 26, 2005 Posts: 4 Location: Utrecht, The Netherlands
Afro88
Audio files: 12
G2 patch files: 79
Posted: Fri Aug 26, 2005 3:31 am Post subject:
FAT! Variation 4 is my favourite...
Get yourself a G2 asap and keep the patches coming dude! |
General Elektrick
Posted: Fri Aug 26, 2005 6:33 am Post subject:
Cool! _________________ Best,
General Elektrick
mother misty
Joined: May 13, 2004 Posts: 681 Location: Ghent / Belgium
G2 patch files: 130
Posted: Fri Sep 02, 2005 12:59 am Post subject:
BSE|Milan wrote: | Still dont have a g2, but that will change soon !
Not sure if this is the bass sound you are looking for ... but i like em dirty :X
this is a more or less a jump up style bass and it might even give you a good reece too
made a few variations check em out
enjoy
Milan |
HEFTIG!!
I really like var 1
by the way! |
BSE|Milan
Posted: Fri Sep 02, 2005 1:06 am Post subject:
thanks
