simple 8 step sequecer for SL
Page 3 of 8 [198 Posts]
Clack
PostPosted: Mon Aug 22, 2005 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
wow that is fantasic , i didnt expect the sound to be so clear. whats the toy ? ( and may i add what a sick toy it must be, some kind of bar fighting toy? )
dnny
PostPosted: Mon Aug 22, 2005 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
yesh thanks for your kind words.
but i don´t know whats wrong whit it - it sounds great but to control it - its nothing i planed. maybe its the crappy toy chip that is adding chaos to this thing - maybe it works nicely whit SL we don´t know - i don´t have my SL ready yet so one of you needs to test this whit it
but yes I'm very pleased whit the results i like randomness and uncontrol very much. so I'm not going to fix this "first attempt" at all - lets just leave it like this. here is another sample for you who liked the first one
i will try to get a pic of the toy when i go and visit my sisters (and i will try to look for more abandoned noise-toys)
daniel
sequli.mp3
 Filename:  sequli.mp3
 Filesize:  1.87 MB
 Downloaded:  1336 Time(s)
www.koelse.org
flickr: cable porn group
Pehr
PostPosted: Wed Aug 24, 2005 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Is it hard to scale it down to a 4-step sequencer? With only one 74HC4016, right?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Pehr
PostPosted: Wed Aug 24, 2005 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Another question I have is why both b and e on the NPN-transistor is connected to ground? If I remeber right there have to be a voltage over b-e to open c-e, right? Confused
YouTube channel
flickr photostream
Clack
PostPosted: Wed Aug 24, 2005 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
yeh all youd have to do is connect step 5 (pin 10) to reset (pin15) then remove everything to do with step 5 and up including the second 4016 on the right and everything connected to it
dnny
PostPosted: Wed Aug 24, 2005 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
problem fixed.
thanks Pehr i got blind and did not see the ground - but if you use leds then you must ad ground so here is what i suggest >>>
its a bit messy but i think u all get the point
daniel
www.koelse.org
Clack
PostPosted: Wed Aug 24, 2005 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
hi sorry for a general electronics question , but why do the LEDs have to go to ground? its somthing I always wonder through my lack of reading books
Macaba
PostPosted: Wed Aug 24, 2005 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
The IC gives out a positive voltage (whatever supply voltage you give it) to the LED, and the other side needs to go to 0v AKA ground. Like hooking it up to a PP3 battery. The + is regarded as 9v, and the - is 0v AKA ground.
Pehr
PostPosted: Fri Aug 26, 2005 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Could there be a pot just before CV out to pitch all the steps simultaneously? Confused
YouTube channel
flickr photostream
Pehr
PostPosted: Fri Aug 26, 2005 11:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could one timer be used for more than one of these sequencers at a time? like a multi-channel? Confused
YouTube channel
flickr photostream
dnny
PostPosted: Sat Aug 27, 2005 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
one timer can be used to many modules - so all the modules are synchronized all in one timer.
you can also ad pot for master CV
daniel
www.koelse.org
Audio files: 107
PostPosted: Sat Aug 27, 2005 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
You probably should put a buffer amplifier on the output of this circuit because different valuses of loads will change the voltage.
To answer Pehr's question, it's not a great idea to just put a pot in series with the output of this devices because it will load the output and also, you can only attenuate the output. This will have the effect of changing the scale.
If you want a transpose, you should use a mixer.
I'd suggest using one opamps, for a mixer of the sequencer CV and a a buffer (from a pot of any other module) and one to invert and buffer the mixer. You will have to switch the connections of the step pots around because mixers invert, but that's no big deal.
 Filesize:  19.72 KB
 Viewed:  15839 Time(s)
Pehr
PostPosted: Sat Aug 27, 2005 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Aha, I see. So the seq. CV and the transpose CV (from a keyboard CV?) is added together, right? resulting in a transpose of the sequence... Confused
YouTube channel
flickr photostream
Audio files: 107
PostPosted: Sat Aug 27, 2005 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes. The transpose signal can be a keyboard, and osc, LFO, or even just a pot.
Add more 100K resistors on the left side of the drawing and you can add more things to mix in.
Clack
PostPosted: Sat Aug 27, 2005 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
yeh i think if you plug the sequencer into both oscilators and adjust the osc pitch while sequencing you get crazy layerd results
Macaba
PostPosted: Tue Dec 27, 2005 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm going to draw up a PCB for this, i just need one thing confirmed:
I don't have any DIP switches around (AKA Piano switches) could somebody confirm that the pins on the bottom of this is arranged like a 16-pin DIL package?
Audio files: 51
PostPosted: Tue Dec 27, 2005 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure what you mean by DIP switches Mac.
We would lose our friends.
So,.........
Macaba
PostPosted: Tue Dec 27, 2005 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Indeed, after checking, it seems they are called DIL switches which answers my question rather well. Seems getting "merry" at christmas hurt a few brain cells. Cool
Audio files: 51
PostPosted: Wed Dec 28, 2005 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Ya Dil Wink
So,.........
dnny
PostPosted: Fri Jan 06, 2006 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry about the DIP/DIL confusion - is just that the vocabulary at my work uses the word "dipping" (in Finnish "dipata")- every time we set up a address of some lights whit these DIL- switches so it got me confused ... sorry.
Macaba have you breadboarded this design?
because it acts wierd whit the toy i have. so it might not function perfectly...
daniel
www.koelse.org
Macaba
PostPosted: Fri Jan 06, 2006 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have not breadboarded it yet, but it looks like I will then, and i'll test it out in every way I can to try spot bugs.
I've been trying to snatch minutes here and there to build a soundlab, and its my intention to add on the sequencer so when I get to that stage, expect the sequencer pcb. (Hell, i might get bored soon and do it tonight Razz)
Smile
Mac
Audio files: 51
PostPosted: Sat Jan 07, 2006 9:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been playing around with this circuit and have noticed a couple of points which aren't obvious from the current schem.
1. The clock inhibit (pin13) needs to be held low otherwise it will float which may inhibit the sequence.
2. The reset on step switches do need to be a rotary so that the reset is held low except when you want it activated. Otherwise you'll get a floater which will repeatedly reset when you don't want it.
I'm about to add a second 4017 and a 4011 (4*2I-NAND) to cascade them for a 16 step.
Looks like I'll be doing a stripboard of this soon.
So,.........
Audio files: 51
PostPosted: Sun Jan 08, 2006 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I went with a 4081 (4*2I-AND) though I'm sure you can get similar results with some nand gates.
Anyway, it's flashing through a 16 step sequence even as we speak, er,,..... type.
I'm gonna have another look at the schematic publisher to see if I can draw it for ya.
So,.........
Macaba
PostPosted: Sun Jan 08, 2006 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, go for it. I've pretty much drawn up the 8 step as a PCB, It could be nice to have the option of 16 steps on the same pcb (even though its alot more IC's!)
Macaba
PostPosted: Sun Jan 08, 2006 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Could we add a 100k resistor to ground at Pin 15, so its held low until a high signal is sent (and that goes to pin 15, which hopefully has a lower resistance than the 100k to ground.)
