<on air> Various Artists September Equinox 2016 LIVE Streaming Concert
+/-12 V DC PSU
Page 1 of 1 [18 Posts]
Pehr
PostPosted: Tue Oct 18, 2005 3:55 am    Post subject: +/-12 V DC PSU Reply with quote  Mark this post and the followings unread
I want to build a +/-12 V DC power supply unit from this transformer
But it says a.c. on it. What more do I need to get at +/-12 V DC PSU? Confused
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
PostPosted: Tue Oct 18, 2005 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
You need the schematics for the rest of it. Check with DJ Justice. He might know of some very basic stuff you can find on the web. This style of PSU are simple and schematics are readily available. I am at work now though, so I have no way of finding this for you.
Pehr
PostPosted: Tue Oct 18, 2005 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Like this one?
YouTube channel
flickr photostream
PostPosted: Tue Oct 18, 2005 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup.. Very Happy
deknow
PostPosted: Tue Oct 18, 2005 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
everything is pretty standard in that schematic, you shouldn't have very much trouble. you can replace the "integrated bridge rectifier" with 4 diodes oriented as shown (this is what makes it dc).
deknow
Macaba
PostPosted: Tue Oct 18, 2005 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
The power supply in that schmatic works very well, mine is good.
Except...
I'm gonna rebuild it one of these days, its a bit shoddy. Don't make it anything less than excellent build quality. Get screw terminal type capacitors, use spade connectors, etc, to make it modular and high quality.
Pehr
PostPosted: Wed Oct 19, 2005 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
1N4148? Confused
YouTube channel
flickr photostream
gubbeper
PostPosted: Wed Oct 19, 2005 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Pehr,
Are you planing to use it with your SoundLab? If so will it work with a 12 volts supply? Confused
/Per
I'm on Twitter
Pehr
PostPosted: Wed Oct 19, 2005 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
gubbeper wrote:
Pehr,
Hi Per Very Happy
Nope, I am planning to use it with a 16 Step Analog Sequencer.
I think the Sound Lab works with +/-12 V, but I already have a +/- 9 V PSU for it Smile
YouTube channel
flickr photostream
PostPosted: Wed Oct 19, 2005 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Pehr,
Do not use 1N4148s they are small signal diodes.
You need some from the 1N400X series. They are recitifier diodes.
4001, 4002, 4004, 4007 etc. As the number goes up the voltage rating goes up. 4004 should be fine. They are 1A/400V.
PostPosted: Wed Oct 19, 2005 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
BTW,
I checked with Ray and yes the SL works fine on +/-12V.
deknow
PostPosted: Wed Oct 19, 2005 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
1N4148?
....i think just about anything would work here, remember, you are bringing the voltage down to 12vac before rectifing. so having a rating of 600 or 1000 volts doesn't mean much in this application. 1n4001 would be fine here. btw, there is nothing wrong with a rectifier assembly either.
deknow
PostPosted: Wed Oct 19, 2005 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you still get 4001s?
deknow
PostPosted: Wed Oct 19, 2005 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
1n4001's are listed at mouser...there seems to be no problem getting them (at least in the states).
deknow
Pehr
PostPosted: Wed Oct 19, 2005 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! Very Happy I've got four 1N4002's that I dug out from an old organ. They might work...
YouTube channel
flickr photostream
deknow
PostPosted: Wed Oct 19, 2005 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
...those should work just fine i think. i was going to suggest that you might find some to canabalize from something old and broken.
deknow
gubbeper
PostPosted: Wed Oct 19, 2005 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool! I was thinking of making that my next project as well. I'll let you go first and make all the mistakes! Very Happy
/Per
I'm on Twitter
PostPosted: Wed Oct 19, 2005 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was just being a smart arse.
Heaps of places don't stock the 4001 or 4002 because the 4004 does the same thing in the same space for the same price.
