Headphones for soundlab
Page 1 of 1 [10 Posts]
Pehr
PostPosted: Sun Aug 14, 2005 12:38 pm    Post subject: Headphones for soundlab Reply with quote  Mark this post and the followings unread
I saw that Alan had an output jack for headphones on one of his soundlabs. I wonder if it is easy to make? Is it just like the main output but with a stereo jack instead? Confused
Audio files: 107
PostPosted: Sun Aug 14, 2005 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Pehr
You will need some sort of headphone amplifier. Here is a link which may provide you with some background. There are many circuits on the web if you google around.
http://www.headwize.com/projects/showproj.php?file=cmoy2_prj.htm
Wild Zebra
PostPosted: Mon Aug 15, 2005 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I've made this little amp http://www.runoffgroove.com/ruby.html
and here is a schem to add a headphone here http://diystompboxes.com/sboxforum/topic-31495.html&highlight=ruby+headphone
and if you need a stripboard layout I think I can find it
These are awesome little amps
"your stripes are killer bro"
Audio files: 107
PostPosted: Mon Aug 15, 2005 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, Mr, Zebra. That one is much better. Buffered input and runs on a single supply voltage. thumb up
Wild Zebra
PostPosted: Mon Aug 15, 2005 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry Mosc didn't mean to trump you Razz . I've build this along with alot of others, its great. Easy and all the parts can even be found at Radio Shack.
Audio files: 107
PostPosted: Mon Aug 15, 2005 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't worry. I gave up Bridge years ago. Wink
Pehr
PostPosted: Mon Aug 15, 2005 9:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Very Happy
I will make one as soon as I have built the SL. It will probably fit in the extra holes on the PCB Cool
kobresia
PostPosted: Tue Aug 16, 2005 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I've built a simple headphone amp for my SL using the design in the link below. The other designs listed may be better alternatives, you decide. Instead of the 250k pot, input is connected to the SL main volume pot. The resistors before output could be way higher, as 100 ohm gives way too much power. I'm using 220 ohm, I'd recommend somewhere in the range of 1k-10k to protect your headphones should you accidentaly turn the volume up.
http://www.paia.com/headbuff.htm
Pehr
PostPosted: Mon Nov 07, 2005 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
0k, I've built both the ruby and the one from headwize now and I have to say that the one from headwize is really good! Very Happy I've built a stereo one for my mp3-player and finally I can hear the bass! Wink
The ruby, is 0k. A little noisy but 0k Smile
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Wild Zebra
PostPosted: Tue Nov 08, 2005 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeh, I'd have to say the ruby is designed more for amplifying a guitar or other instrument and less like a "power amp" or whatever you wanna call it. The ruby I mabe gets used mostly for sittin around playing guitar of the SL on a trip. The gain is pretty nice if'n you like that sort of thing.
I'll have to try the headwise amp. Thanks for the update.
