  bingsatellites Mostly Ambient
Emulating Waldorf Pulse Oscillators
Page 1 of 2 [29 Posts]
monobass
G2 patch files: 12
PostPosted: Sat Nov 12, 2005 4:24 pm    Post subject: Emulating Waldorf Pulse Oscillators Reply with quote  Mark this post and the followings unread
The patch attached is an emulation of a Waldorf Pulse patch I use in one of my tracks which I want to perform live using only the G2. I was very pleased with how similar it actually sounds in comparison.. but I'd like to go further and do a complete Pulse emulation (the patch attached has many Pulse features missing).
After looking at the raw Waldorf Oscs with a software oscilloscope I did a little shaping of the G2 Oscillators to look/sound more like the Waldorf... but i've never tried this sort of waveshaping before.. so if anyone has any good tips on how to achieve waveshapes similar to these on the G2 like those pictured below then give me a shout!
I was very surpirsed how similar the Pulse and Saw actually look compared to the G2's more 'perfect' waveforms... It's all in that gradient.
(The Triangle wave is actually just the sawtooth with some lo-pass applied, it was simple to tweak the filter on the Saw on the Waldorf to achieve the identical waveshape.)
Pulse test.pch2
 Filename:  Pulse test.pch2
 Filesize:  3.44 KB
 Downloaded:  607 Time(s)
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sat Nov 12, 2005 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if i can tell you anything that will get these specific shapes, but I have some general guidelines.
You can do a lot of subtle shaping tricks with just a shaper and crossfader. For example:
Say you want to flatten or round off the top of a saw wave but not the bottom (lots of analog synths have a saw wave with this kind of asymetrical shape). Connect the saw to one input of a crossfader. Also connect it to a shaper module set to INVx3 and connect the shaper output to the second crossfader input. Now here's the trick - also connect the saw to the CONTROL input of the crossfader and set both crossfader controls to 12 o'clock. Now, when the saw goes positive, the crossfader output passes the shaped saw, and when the wave goes negative, it passes the unprocessed saw. So the final wave is only 'shaped' on the top half.
You can use this idea for lots of variations to make waveforms that are shaped differently on the top & bottom. Try using two different shapers on the two inputs. Try overdrive modules or wavewrappers. Try a triangle wave instead of a saw. Try using a saw wave on one input and a sync'd pulse wave on the second input. Etc.
Another way to get asymetrical shaping is to pass the wave through a level shifter to make it positive only, then through a shaper, and then another level shifter to make it bipolar again.
Another way to shape raw waveforms is by using a filter that tracks the waveform frequency. Try using a highpass filter set to a relatively low fc with a good bit of resonance. Normally, we think of HPFs as something you use to make a signal sound thin, but when you set it to a low fc and crank the resonance, it will emphasize the fundamental or one of the low harmonics, which can make the waveform sound more big & bassy.
Enjoy!
Dave Peck
monobass
G2 patch files: 12
PostPosted: Sat Nov 12, 2005 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great stuff thanks Dave Smile
Plenty for me to be trying out there, that HP trick is very nice.
(I've attached my patch trying these techniques out if anyone wants a look)
davep_wave_examples.pch2
 Filename:  davep_wave_examples.pch2
 Filesize:  1.92 KB
 Downloaded:  646 Time(s)
monobass
G2 patch files: 12
PostPosted: Sat Nov 12, 2005 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok here's my first attempt at the Pulse wave...
Not bad although as shown in the circled area i'm getting some funny resonance type things in the middle of the 'down slope'. think it might be to do with the way i'm using a squarewave to sync... not sure.
pulse_wave_01.pch2
 Filename:  pulse_wave_01.pch2
 Filesize:  1.3 KB
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Sat Nov 12, 2005 8:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
That’s looking good, the funny spike I think is a Sinc pulse and is part of Clavia’s anti-aliasing, they pop up sometimes when doing wave shaping.
I had a think about this question while waiting in the supermarket car park. Here is the result. Using a compare to get a rectangle from the sawtooth and then using the sawtooth to AM the square or a saturated sawtooth.
What soft scope are you using BTW?
 Filesize:  2.63 KB
 Viewed:  12149 Time(s)
WaldPulse.pch2
wave shaping
 Filename:  WaldPulse.pch2
 Filesize:  1.4 KB
 Downloaded:  767 Time(s)
monobass
G2 patch files: 12
PostPosted: Sat Nov 12, 2005 8:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey G2Ian,
Ah nice technique... and I'm stunned as to how close the pulse wave sounds to the real thing in a side by side comparison!.. and the saw will only take a little tweaking to get it spot on I think.
Great stuff (hope you didn't forget any shopping due to contemplating this Wink )
I'm using a softscope in OSX called Wavewindow
http://www.macmusic.org/softs/view.php/lang/EN/id/3262/
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Sat Nov 12, 2005 10:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
monobass wrote:
(hope you didn't forget any shopping due to contemplating this)
Elise (3) fell asleep on the way so I got to sit in the car with her while her mum and three brothers did the shopping Very Happy
Mac, pitty, it looks very nice.
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sat Nov 12, 2005 10:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I put a patch here:
http://electro-music.com/forum/post-57677.html#57677
...that uses some of the ideas I described. More explanation in that post. Smile
Dave Peck
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Nov 13, 2005 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Dave,
Your discussion of Shaping tricks made me try out something in a patch which I was going to post (a digiridoo-ish thing), but I have once again screwed up and you can't open it in the editor Embarassed ...
But time will heal this I hope ... unless the file format changes again ...
/Dasz
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Nov 13, 2005 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Folks,
And so I have created another patch (no-where as good as the one that won't open in the editor).
A hard patch to read. But the idea is I change the DC offset (which splits the osc into negative and positive only waveforms with different shaping applied to each. Then we mix the signals through a LP/HP/BP ... after wich shaping is once again appied to each band (LP/HP & BP separately)... finally a saw osc is added to give this patch some basis in pitch ...
A very dark and evolving patch, not my best ...
/Dasz
DaveP2_DZ.pch2
Strange dark evolving shaper-ed patch inspired by Dave P's article and cambodia visit ...
 Filename:  DaveP2_DZ.pch2
 Filesize:  4.58 KB
 Downloaded:  722 Time(s)
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sun Nov 13, 2005 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Dasz,
Nice, I like it!
I was playing around with it & ended up with a slight mod, mostly just slowing things down (Variation 2). I like the slowly shifting harmonic content a lot. Sounds a bit like a large table saw in a cave.
BTW, how can you screw up a patch so that it won't open in the Editor?? That sounds really annoying and I'd like to know how to avoid that.
davep2_dz_820mod.pch2
 Filename:  davep2_dz_820mod.pch2
 Filesize:  4.59 KB
 Downloaded:  669 Time(s)
Dave Peck
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Nov 13, 2005 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dave,
Thanks for the kind words ...
Uhm, the patches do not open in v1.32 Wink ... but they do open on one of my G2's Wink ...
I like the modded patch ... I should do more variations ...
/Dasz
Audio files: 116
G2 patch files: 317
PostPosted: Sun Nov 13, 2005 6:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Avoid beta testing then :-)
and70it
PostPosted: Mon Nov 14, 2005 12:42 am    Post subject: wave window Reply with quote  Mark this post and the followings unread
can wave window work in OS X 10.3 as standalone?
monobass
G2 patch files: 12
PostPosted: Mon Nov 14, 2005 5:14 am    Post subject: Re: wave window Reply with quote  Mark this post and the followings unread
Yep, that's how I use it. It might be too simple for some peoples tastes, but great for just scoping waves, check out the demo.
G2DREAM
PostPosted: Tue Nov 15, 2005 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there any so simple and good looking software for windows?
_______________
cyber-evolution
Audio files: 116
G2 patch files: 317
PostPosted: Tue Nov 15, 2005 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe http://www.sonicspot.com/wavetools/wavetools.html ?
It says it needs windows 3.1, but once I had it running under XP, although that was before installing SP2 I think.
G2DREAM
PostPosted: Tue Nov 15, 2005 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, doesn't work on me but thanks anyway for the info man!
______________
cyber-evolution
cebec
G2 patch files: 31
PostPosted: Tue Nov 15, 2005 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, there're always these:
Visual Analyser
http://digilander.libero.it/hsoft/
OscilloMeter
http://shmelyoff.nm.ru/
i wouldn't call them pretty or simple, though.
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Tue Nov 15, 2005 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use the first one (VA.EXE) but not the latest version which looks better but mysteriously won't run on my XP machine.
cebec
G2 patch files: 31
PostPosted: Tue Nov 15, 2005 9:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, VA's latest version gives me all kinds of trouble, lately... maybe due to XP updates? i'm not sure... it worked fine once upon a time...
Question
G2DREAM
PostPosted: Wed Nov 16, 2005 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok guys i will chek them out,thank you!
_____________
cyber-evolution
BobTheDog
PostPosted: Thu Nov 17, 2005 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Does anyone know of one that uses ASIO?
Andy
foxystoat
PostPosted: Fri Nov 18, 2005 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Andy
This one isn't stand-alone, but it will run in ASIO if your host is set up for it:
s(M)exoscope
Regards,
Benjamin W.
monobass
G2 patch files: 12
PostPosted: Wed Nov 23, 2005 7:07 pm    Post subject: Work In Progress Reply with quote  Mark this post and the followings unread
This is as far as I got with the Pulse patch, still plenty to do and by no means is this patch as efficient as it could be. It could be two more weeks before I have time to finish it though.
I'm going to do a one slot version without the 4 part modulation matrix.. and then a two slot patch with a full emulation (apart from the arpeg).
I've also almost finished a complete midi remote control patch for the real Pulse.. although unfortunately due to the mysterious 60 module CtrlSend limit this will be a two slotter as well.
Big thanks due to Davep and G2Ian for their help to date! (and Robs ubiquitous spectrum tilter).
Waldorf_pulse_302.pch2
Waldorf Pulse emulation. Work in progress.
 Filename:  Waldorf_pulse_302.pch2
 Filesize:  7.2 KB
 Downloaded:  716 Time(s)
Niio1
