Implementing a counter over a certain time period
Page 1 of 1 [7 Posts]
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Nov 23, 2005 12:28 am    Post subject: Implementing a counter over a certain time period Reply with quote  Mark this post and the followings unread
I'm hoping someone could help me out with this. I'm trying to create a counter that counts events. When the counted events reaches 3/4/5/6/whatever before the timer runs out another event is triggered.
Can anyone help? Or am I thinking about this the wrong way... is there another way to achieve what I want without using a counter mechanism?
Thanks
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Nov 23, 2005 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok so I've built one with a sequencer... Is there a cheaper way that anyone knows of?
It counts 3 events. If there are 3 events in the time denoted in the delay then the second event is triggered. I'm not sure if it works correctly though, as I'm pretty sure the delay passes all random pulses, just delayed, instead of just passing the first pulse of the group of 3...
Counter.pch2
Counting patch
 Filename:  Counter.pch2
 Filesize:  1.51 KB
 Downloaded:  1048 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Nov 23, 2005 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Effective and cheap solution.
My solution is more expensive, but lets you select the counter limit with a numerical control rather than having to set gates in the sequencer. You could even dynamically modulate it.
It also lets you use the counting variable for whatever purpose you might want.
TimeLimitCountTK.pch2
 Filename:  TimeLimitCountTK.pch2
 Filesize:  1.21 KB
 Downloaded:  1118 Time(s)
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Nov 23, 2005 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Tim, very nice. It took me a little while to figure it out Wink It hadn't occured to me to use a mixer in a feedback loop... I'll be using yours I think, sure it uses slightly more dsp/memory, but at least it works exactly as it should.
Cheers Smile
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Nov 23, 2005 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad it's useful.
It's based on a counter circuit I designed some time ago. I even built expo-tracking sawtooth oscillators with it once (which can be found here: http://www.electro-music.com/forum/topic-6966.html)
revelingjohn
PostPosted: Mon May 26, 2008 7:49 pm    Post subject: How does this work?
Subject description: Where do I put the thingy that makes the stuff happen?
This is an awesome patch. Unfortunately I'm not so bright with the workings of these patches. I want to count logic "clicks" over a time period of say 100ms. Where do I insert the bus that my logic signals are flowing on so this doo-hickey will count them? How do I start (yes I pushed the "start" button but there is clearly more to it)? how do I specify the time frame? And most importantly where does the resulting count spit out of? Is it in the form of an amplitude value or a frequency value (amplitude would be most helpful)?
Alternatively, does anyone know how to convert a frequency value into an amplitude value, i.e. "clicks per second" to voltage. I guess that would be period to amplitude....anyway, is it possible?
Audio files: 251
PostPosted: Tue May 27, 2008 1:57 pm    Post subject: Re: How does this work?
Try the Zero Crossing Counter or the Pitch Track modules (on the Note tab)
