substitutes for Sound Lab IC´s
Page 1 of 3 [62 Posts]
Goto page: 1, 2, 3 Next
dnny
PostPosted: Tue Mar 22, 2005 2:23 am    Post subject:  substitutes for Sound Lab IC´s Reply with quote  Mark this post and the followings unread
READ all the posts of this topic ...you will find more substitutes
Hello all i just had some extra time so i made list of the substitutes for Sound Lab IC´s. hope this is useful to somebody.
first there is LF442 (Dual JFET input op-amp)
at least the following IC´s share the same pinouts and therefore can replace LF442
LF412
LT1057
LT1113
LT1457
OP215
TL092
http://www.alldatasheet.com/datasheet-pdf/pdf/LINER/LF412A.html
http://www.alldatasheet.com/datasheet-pdf/pdf/LINER/LT1057.html
http://www.alldatasheet.com/datasheet-pdf/pdf/LINER/LT1113.html
http://www.alldatasheet.com/datasheet-pdf/pdf/LINER/LT1457.html
http://www.alldatasheet.com/datasheet-pdf/pdf/AD/OP-215.html
http://www.alldatasheet.com/datasheet-pdf/pdf/TI/TL092.html
Second comes LF444 (Quad JFET input op-amp)
at least the following IC´s share the same pinouts and therefore can replace LF444
LT1058
LF147
LF247
LF347
NTE859
OP482
TL074
http://www.alldatasheet.com/datasheet-pdf/pdf/NSC/LF147.html
http://www.alldatasheet.com/datasheet-pdf/pdf/LINER/LT1058.html
http://www.alldatasheet.com/datasheet-pdf/pdf/NTE/NTE859.html
http://www.alldatasheet.com/datasheet-pdf/pdf/AD/OP282.html
http://www.alldatasheet.com/datasheet-pdf/view/TI/TL074.html
Third comes LM13700 (dual Operational Transconductance Amp)
at least the following IC´s share the same pinouts and therefore can replace LM13700
LM13600
NE5517
AU5517
NTE870
http://www.alldatasheet.com/datasheet-pdf/pdf/NSC/LM13600.html
http://www.alldatasheet.com/datasheet-pdf/pdf/PHILIPS/NE5517.html
http://www.alldatasheet.com/datasheet-pdf/pdf/PHILIPS/AU5517D.html
http://www.alldatasheet.com/datasheet-pdf/pdf/NTE/NTE870.html
and then there is
MPF102 (N JFET Amplifier)
this info is gathered from other post
so try these:
2N5457
BF256A
PN4416
J202
2N5951
2N3819
http://www.alldatasheet.com/datasheet-pdf/pdf/11484/ONSEMI/2N5457.html
http://www.alldatasheet.com/datasheet-pdf/pdf/77365/MOTOROLA/BF256A.html
http://www.alldatasheet.com/datasheet-pdf/pdf/18727/PHILIPS/PN4416.html
http://www.alldatasheet.com/datasheet-pdf/pdf/53143/FAIRCHILD/J202.html
http://www.alldatasheet.com/datasheet-pdf/pdf/50023/FAIRCHILD/2N5951.html
http://www.alldatasheet.com/datasheet-pdf/pdf/15075/PHILIPS/2N3819.html
NOTICE that the pins are oriented differently so make sure you insert it into the circuit board correctly.
greetings to all Sound Lab builders
Daniel
[edit: added the MPF102 substitutes]
pinouts for IC´s
 Filesize:  41.14 KB
 Viewed:  26840 Time(s)
adhdboy
PostPosted: Tue Mar 22, 2005 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
This is very cool. Thanks for taking the time to do this.
adhdboy
There 10 kinds of people in this world that understand binary those that do and those that don't.
Alex_D_Steak
PostPosted: Thu Mar 24, 2005 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
great work, dnny!
@adhdboy
might be worth including a link to this post on your site Smile
Doctor... who?
Etaoin
PostPosted: Wed Oct 26, 2005 10:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
More LF442 replacements: TL072 (low noise), TL062 (low power)
More LF444 replacements: TL064 (low power)
TL082 and TL084 are also options.
dnny
PostPosted: Thu Oct 27, 2005 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Etaoin for the substitutes.
and thanks v-un-v for making this post "Sticky"
i added the subtitutes for the MPF102.
daniel
www.koelse.org
flickr: cable porn group
PostPosted: Thu Oct 27, 2005 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
no probs dnny :)
I'm gonna address the other issues as soon as Mosc sorts out some current server problems.
Tom
Pehr
PostPosted: Fri Oct 28, 2005 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I have used NTE451 instead of the MPF102, it works perfect Smile
a bit expensive though Confused
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Audio files: 51
PostPosted: Sat Oct 29, 2005 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
What does "sticky" mean? Confused
We would lose our friends.
So,.........
dnny
PostPosted: Mon Oct 31, 2005 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
i think that sticky means
the post will stick on top of the list no matter what.
so it will not get buried by time.
www.koelse.org
PostPosted: Mon Oct 31, 2005 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
What does "sticky" mean? :?
I'll probably do the same for your veroboard designs as soon as the become more 'buried'!
gubbeper
PostPosted: Mon Oct 31, 2005 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
On the subject of substitutes I’ve been thinking about the 1N914 diode and whether it could be replaced by the 1N4148?
In the partslist for the 1V/Octave Voltage Controlled Oscillator the diodes are only refered to as High Speed Sw Diodes. Could the 1N4148 be used here as well? Confused
/Per
I'm on Twitter
Audio files: 51
PostPosted: Mon Oct 31, 2005 1:21 am    Post subject: Reply with quote  Mark this post and the followings unread
The 1N914 and the 1N4148 are almost exactly the same. I haven't come across a circuit which quotes one and doesn't work with the other. You can however get diodes that switch faster than either of them.
So,.........
Pehr
PostPosted: Sat Dec 03, 2005 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Does anyone know if the LM324 is a good substitute for LF444? Confused
YouTube channel
flickr photostream
Audio files: 51
PostPosted: Sat Dec 03, 2005 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't see anything wrong with it.
I'm not an expert at reading Op-Amp specs though.
Pinout, and power supply are fine, so I'd give it a go.
So,.........
Etaoin
PostPosted: Thu Dec 08, 2005 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
LF444 is a JFET input opamp, LM324 isn't. So no.
Etaoin
PostPosted: Thu Dec 08, 2005 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
By the way, I'm currently building RJW's VCO and found that replacing the LF411 and LF442 with their TL "equivalents" doesn't always work. I can't get the 1V/Oct scaling right with these substitutes in. So the exact specs might be essential in some applications.
This might also affect the LF444 used in the SL's oscillators. I got mine to work with TL064's, but judging from my experience with the VCO, the original LF might have been better.
dnny
PostPosted: Thu Dec 08, 2005 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the info.
the "equivalents" are picked up whit only equal pinnouts . not by the specs Sad
Ray W wrote:
Op Amp Substitution?
Pretty much any quad JFET input op-amp with the same pinout will do to replace the LF444 and pretty much any dual JFET input op-amp with the same pinout will do to replace the LF442. I chose these because they draw very little current and they are still in full production. There are many many JFET input op-amps in full production. Search for "JFET input" on your favorite part suppliers website and they'll be there.
Etaoin
PostPosted: Thu Dec 08, 2005 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I should probably add that my LF411 and 442 are still on order, so although I can't get the VCO to work properly with TL061 and TL062 replacements, I can't yet say it does work with the LF's! I'm just assuming that the reason I can't get it tuned is because I tried replacements. All other components are as specified and it does work fine apart from the tuning.
PostPosted: Thu Dec 08, 2005 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Etaoin,
This is a bit off topic. Do you mind starting afresh in a new thread?- as I want to try and keep this thread reference material as far as possible- and of course open source- and no need for locking it. Thanks!
Tom
ACHTUNG!
Etaoin
PostPosted: Thu Dec 08, 2005 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was trying to explain that it was wrong to include my comment at the top of this thread. If I say that elsewhere, it's of not much use. I'd suggest just removing my messages from this thread.
PostPosted: Sun Dec 11, 2005 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
No offense mate, but I've got enough things on my plate right now- than having to chase list members who aren't thinking before pressing return. (This goes for everyone btw!)
I hope you understand Smile
If you've got a component which works as a substitute for any component on Ray's site- then by all means- put it here. But if you have a problem with a substituted component listed on this thread, then please start a fresh thread- then everyone can gain knowledge from your discovered experiences- otherwise everything just gets buried.
You could also include a link in your new post so people understand where you are coming from?
ACHTUNG!
seraph
Editor
Editor
Audio files: 31
PostPosted: Sun Dec 11, 2005 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
you can do it yourself Very Happy
Politics is the entertainment division of the military industrial complex - Frank Zappa
Pehr
PostPosted: Mon Jan 09, 2006 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
What about TL082 and TL084? Those are JFET, right?
YouTube channel
flickr photostream
Audio files: 51
PostPosted: Mon Jan 09, 2006 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah,
Ray said there's some specific problem with the TLXXX series, I think it was in the VCO, can't remember, but apart from that they're fine.
So,.........
Mikmo
PostPosted: Thu Apr 06, 2006 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a little warning.
You can't always substitute 13600 for 13700. 13700 have linearisation diodes, 13600 does not.
If Rays design uses these diodes you can NOT use the 13600 in stead of the 13700.
I do not know if this is the case though.
Stay Cool
Mikael
http://www.mikmo.dk
Niio2
