<on air> PHOBoS presents: There is no show, or is there ?
Alternate ways of generating waveforms???
Page 1 of 1 [14 Posts]
vlab
PostPosted: Thu Dec 22, 2005 10:02 pm    Post subject: Alternate ways of generating waveforms??? Reply with quote  Mark this post and the followings unread
Hi all !
Sorry if this topic has been discussed before,
I was playing around the factory patches the other day,
and came across a few patches that used sine waves, then waveshaped using rectifiers, overdrives, and clippers to shape other waveforms like saw and square.
It was a great discovery for me, I managed to makes some really great tones I never heard out of any other VA I have (or had) . The only one I've been unable to generate so far is a PWM wave,
Anyone managed to do this ?
Any help or contribution (inn patches or discussion) would be great !!
I can't wait to modify the OSC's from my favorite patches with this..
it sounds a gazillion times more than the stock Oscillators....
Thanks again !!
Vlab
G2 patch files: 584
PostPosted: Fri Dec 23, 2005 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is one way using the comparesig module. Not as well anti-aliased as the Clavia PWM, ok for bass sounds.
PWM.pch2
hand made pwm
 Filename:  PWM.pch2
 Filesize:  1.23 KB
 Downloaded:  701 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Dec 23, 2005 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey vlab,
Have you used the control seqeuncer driven by an osc, or a level sequencer driven by a hifreq pulse... both of these methods produce wavetabl-ish patches ...
btw, where in canada are you?
/Dasz
Axiom
G2 patch files: 28
PostPosted: Sat Dec 24, 2005 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Why not an LFO that feeds a Square shape? Wink
This is, so far, the simplest way to have PWM.
PWM.pch2
 Filename:  PWM.pch2
 Filesize:  937 Bytes
 Downloaded:  592 Time(s)
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
vlab
PostPosted: Sat Dec 24, 2005 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Axiom,
As the title of my message reads, ALTERNATE ways of generating waveforms, of course I know how to modulate a standard OSC,s square wave to do PWM.... Otherwise I'd be in deep troubles with a G2X (!!!)
But I have to agree with you that the LFO modulating standard square is the simplest way of doing it, but my goal here is to have the best sound possible....
Take a look at the previous messages by G2Ian and Dasz.
Those suggestions are great ways to change the "voice" of
the G2, compared to the standard OSC modules.
For my part, I find the sonic palette much more interesting using
those methods instead of bulk OSC, the sound is thicker, the harmonics
sounds more natural to me, and you can modulate the waveshape in ways OSC modules can't reach.
I'd just wish that Clavia could feature some kind of "module container"
so we could build this kind of OSC modules and save them as macro and free some space in the main screen....
Vlab
vlab
PostPosted: Sat Dec 24, 2005 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Dasz,
I'm from Montreal !!
I guess I should add this info to my profile..
Thanks for the step sequencer tip !
Indeed it sounds kinda wavetable-ish,
but with it's own FM wierd twist, in a way my Waldorfs MW1 and XT
cant reach !!
What a great synth !
Vlab
cebec
G2 patch files: 31
PostPosted: Sat Dec 24, 2005 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Vlab
they used to. I've never seen how it works but it was in the NM Classic v2.0. right now, it's a top wish for myself and i'll bet many other people.
the building blocks subforum is a step towards this. if clavia ever (re)implement even the most rudimentary macro system then these blocks can be dropped right in.
vlab
PostPosted: Sat Dec 24, 2005 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really ?? I have a Classic Modular too, with the latest version,
and I've never seen such a feature, why did they took it out in V3?
Rob
G2 patch files: 109
PostPosted: Sat Dec 24, 2005 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
It was a way of saving a couple of modules and later recall that group of modules in another patch. It wasn't really macros or grouping a couple of modules into one 'greater' module, as the individual modules were kept.
Rob
G2 patch files: 109
PostPosted: Sat Dec 24, 2005 4:52 pm    Post subject: Re: Alternate ways of generating waveforms??? Reply with quote  Mark this post and the followings unread
vlab wrote:
The only one I've been unable to generate so far is a PWM wave. Anyone managed to do this?
Yep, it is quite simple with the Clipper module in a feedback loop in a mixer. Used this way the clipper turns into sort of an analog style comparator with controllable gain. If the gain is high (100% feedback) the slopes of the resulting pulse will be virtually vertical. With less gain the slopes will slightly tilt and the sound will be smoother. In fact it is possible to morph between a triangle and a squarewave with this circuit by controlling the amount of feedback.
Clipper must be set to symmetric and the input waveform must be either a triangle or a sinewave. The amount of feedback defines the slope of the leading and trailing edges of the pulse. The trick to get PWM is to add a slowly varying value to the triangle waveform.
The advantage if using a triangle wave to generate a PWM pulse wave is that the perceived detune goes both lower and higher and the resulting pitch centers around the pitch of the triangle wave. This makes it more easy to use audio rate waves tuned to the basic pitch to create interesting ringmodulated pulses types of sounds. See patch 3.
PWM_DIY.pch2
Generating a PWM sound from a triangle wave
 Filename:  PWM_DIY.pch2
 Filesize:  1.04 KB
 Downloaded:  585 Time(s)
PWM_DIY2.pch2
Fuller PWM sound from a triangle
 Filename:  PWM_DIY2.pch2
 Filesize:  1.75 KB
 Downloaded:  602 Time(s)
PWM_DIY3.pch2
Audio rate PWM from a triangle wave
 Filename:  PWM_DIY3.pch2
 Filesize:  1.56 KB
 Downloaded:  631 Time(s)
Rob
G2 patch files: 109
PostPosted: Sat Dec 24, 2005 4:54 pm    Post subject: Re: Alternate ways of generating waveforms??? Reply with quote  Mark this post and the followings unread
Still the principle also works with sawtooth waves and is interesting to get e.g. a slightly lively sawtooth waveform. Feedback and modulation should be shallow to retain the sawtooth character. The fundamental will be slightly boosted. See patch 4.
And a little synth line with example 4.
PWM_DIY4.pch2
Generating a lively sawtooth with the PWM trick
 Filename:  PWM_DIY4.pch2
 Filesize:  1.1 KB
 Downloaded:  615 Time(s)
PWM_DIY5.pch2
And a little synth made with example 4.
 Filename:  PWM_DIY5.pch2
 Filesize:  2.05 KB
 Downloaded:  610 Time(s)
Axiom
G2 patch files: 28
PostPosted: Sat Dec 24, 2005 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rob, can I have a 10th of your knowledge as Xmas gift? Razz
dho.. too late Very Happy
Luca
p.s.:
merry xmas from Italy.
Rob
G2 patch files: 109
PostPosted: Sat Dec 24, 2005 5:19 pm    Post subject: Re: Alternate ways of generating waveforms??? Reply with quote  Mark this post and the followings unread
It is also possible to use a 'compressive nonlinear gain cell' instead of a clipper. In this case harmonics are built up in a gradual way and the resulting sound is a bit darker.
PWM_DIY6.pch2
Generating a PWM sound from a triangle with a compressive nonlinear gain cell.
 Filename:  PWM_DIY6.pch2
 Filesize:  1.28 KB
 Downloaded:  618 Time(s)
vlab
PostPosted: Fri Dec 30, 2005 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Rob,
Thanks so much for this info, it's exactly what I was looking for !
and also, thanks to all who replied, I learned a lot !
Vlab
Niio2
