First G2 Patch- Noise Synth 1
Page 1 of 1 [8 Posts]
TheRain
G2 patch files: 9
PostPosted: Wed Dec 28, 2005 7:49 pm    Post subject:  First G2 Patch- Noise Synth 1
Subject description: A PM based noise synth with Res Low Pass and Custom Comb Filter
Hi guys.. My G2 came today and I am freakin' blown away... I absolutely love it! So here is a patch I worked hard on today... It is a Noise synth composed of a PM osc modulated by Noise to get a little different character of noise sound... a little more grainy which is how I like it Very Happy I added a "scream" parameter just for fun. There is an amplitude env for the Osc, a separate envelope with tuneable amount for the filter as well as a dedicated filter LFO, and a Comb filtering section designed from a mod delay with it's own LFO as well as a custom "stereo split" parameter.
The panel is organized like so:
A: OSC section
B. Filter with page two for the LFO
C. Comb with LFO on first page
I made a variation for all of the 8 slots and color coded the modules in the editor.... yes I've been busy for a first day first time user Wink
I've been lurking the past few days and have been testing patches from Rob and g2ian and such using the Editor Demo... you guys are incredible... look forward to learning stuff from you all.
Noise Synth 1.pch2
A PM osc modulated by noise feeds a low pass and customize comb filter. A first try for a new guy.
 Filename:  Noise Synth 1.pch2
 Filesize:  2.7 KB
 Downloaded:  866 Time(s)
Audio files: 224
G2 patch files: 319
PostPosted: Wed Dec 28, 2005 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome TheRain, or Collin I guess & congratulations with your new G2.
I don't have any playability enhancement utils hooked up to my G2 engines right now (almost never actually), which makes your patch hard to play with, but it's different from what people usually send as a first patch, I like that :-)
TheRain
G2 patch files: 9
PostPosted: Wed Dec 28, 2005 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks man... I recognize you from some of your other posts around here. Sorry this is not like a sequenced synth or some such Wink I spose there is still room on the front panel to make that worth while for me as well. If you have some advices too I'm learning here and I know I probably did not make a very optimized setup here or something... or there are better/cleaner ways of doing certain things and stuff.
Audio files: 224
G2 patch files: 319
PostPosted: Wed Dec 28, 2005 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dont be sorry, you are experimenting and not doing bad at all, having ideas about what you want to achieve and liking it more gritty & stuf like that, I've seen worse :-)
Did you already find the "general" resources like those listed in http://www.iaf.nl/Users/BlueHell/html/nm/nm-links.htm or
http://mail.electro-music.com/mailman/listinfo/nord-modular ?
There is a lot of interesting stuff available on the web.
TheRain
G2 patch files: 9
PostPosted: Wed Dec 28, 2005 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot man.. i've looked through some of those, but others i hadn't seen before.
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Thu Dec 29, 2005 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice patch.
Seems you know your way around a modular synthesiser. What did you use before the G2?
We can dance if we want to, we’ve got all your life and mine.
TheRain
G2 patch files: 9
PostPosted: Thu Dec 29, 2005 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi g2ian... thanks very much. I constructed a few instruments in Reaktor. But I am generally a synth addict, prolly much like most people here... I've owned a ton of different synths which I study like crazy and then trade out for something different. I am also a software/dsp/electrical engineering student in my second year of college, but I have never programmed any dsp type things from scratch... though I hope to soon.
What is your background? I noticed you are really active here and I've tested a bunch of your patches which were all quite cool.
TheRain
G2 patch files: 9
PostPosted: Thu Dec 29, 2005 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking this patch through again and looked at some other people's patches and realized that I was using the Constant module unnecesarily sometimes because I didn't realize you could rename some parameters and not just the modules themselves... hehe, I was using Constant modules as renamable parameters Wink
Another time I was using Constant was to connect a single knob to two separate modules to control both with one knob and group them as a single parameter... for instance in the comb filter, there is one knob that controls both the delay of the left and the right. Is there a better way of going about this??
