Joined: Feb 04, 2005 Posts: 2130 Location: Nottingham, UK
Audio files: 150
Posted: Thu Dec 29, 2005 3:48 pm Post subject:
How do I test that my stream is working? _________________ Jez
music | adventures in sound |
Joined: Apr 03, 2004 Posts: 19599 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Thu Dec 29, 2005 3:58 pm Post subject:
You could start a player and for the URL use http://radio.electro-music.com:<portnr> where <portnr> is one of the port numbers Howard gave to you - you can try both, both should work. And when that is working all should be OK, those ports will be manually plugged through to the main ports when it's "your time".
A few messages back I gave some examples for various players.
The main ports seem to be conected to the Noodle Radio now, but that will be a bit messy for the time being, as I'm working on making a program rather than doing serious streaming :-)
Ehm, and it should do some bug finding ... _________________ Jan |
Audio files: 150
Posted: Thu Dec 29, 2005 4:11 pm Post subject:
I have set up Winamp with the shoutcast plugin as Mosc explained and clicked Connect. As far as I can tell something is being sent, I just don't know whether it is getting through. Is there any way to check? Last edited by modulator_esp on Thu Dec 29, 2005 6:15 pm; edited 1 time in total |
deknow
Posted: Thu Dec 29, 2005 4:14 pm Post subject:
...i was able to run foobar2000 listening to the stream at the same time winamp was sending it (make sure to point specifically to the stream you are sending).
deknow |
Audio files: 116
G2 patch files: 317
Posted: Thu Dec 29, 2005 4:24 pm Post subject:
| modulator_esp wrote: | | I have set up Winamp with the shoutcast plugin as Mosc explained and Connect. As far as I can tell something is being sent, I just don't know whether it is getting through. Is there any way to check? |
Yes, that's what I tried to explain. You can listen to the same ports you send on, and it will be running through the server then.
Just don't use WinAmp to monitor as you are using that to send, but almost any player will be able to play shoutcast streams. The audio you get back back will b delayed by some tens of seconds. _________________ Jan |
Audio files: 150
Posted: Thu Dec 29, 2005 4:31 pm Post subject:
Thank you both, I had not realised I had to change the port on the monitor to match that on the transmitter. Everything is OK now  _________________ Jez
mtvic
Joined: Feb 03, 2003 Posts: 461 Location: Abington PA
Posted: Thu Dec 29, 2005 7:13 pm Post subject:
HELP |
SH_T.
I can' t get these plug ins to work .
Shoutcast gives me invalid password message when I try to connect
oddcast gives me LAME .dll error when Itry to connect
Waz up wid dis ch_t mon
Please help
I really want to do this.
sonically all of yalls
mtvic _________________ "I'm the transmitter' I give information."
>>> Kraftwerk Radioactivity<<< |
Audio files: 116
G2 patch files: 317
Posted: Thu Dec 29, 2005 7:29 pm Post subject:
Ok, lets try to sort it out.
For the Shoutcast plugin : are you using the port numbers/passwords Howard sent you ?
I had some confusing characters in the passwords I got from Howard, cutting those out of Howard's message and pasting them into the password box solved a connection problem for me.
For OddCast, are you using the WinAmp plugin, the Foobar plugin or the stand-alone version ?
You'll need the file lame_enc.dll for the OddCast standalone it must be in the folder where the OddCast exe is, for the plugin I guess it should be in the WinAmp folder or in the WinAmp\plugin folder. WinAmp itself uses lamedll.dll which seems to be a different lame encoder. _________________ Jan |
mtvic
Posted: Fri Dec 30, 2005 9:28 am Post subject:
Q:For the Shoutcast plugin : are you using the port numbers/passwords Howard sent you?
A: yes
I will try cutting and pasting and get back toyou
Mohoyoho
Posted: Fri Dec 30, 2005 11:10 am Post subject:
I found this out the hard way, and hopefully this might help you, Michael. Make sure there is no file loaded in Winamp when you have the plugin Shoutcast Source's Input on Soundcard. On my Windows 2000 it will freeze the whole computer if it's on Soundcard and there's a MP3 loaded and trying to play. If you want to play a file put the input on Winamp. If you want to play live through the soundboard, clear it out (there's a menu for that) and then change the input from Winamp to Soundcard.
If you still are having problems, Winamp has a pretty extensive support system. There are lots of posts on their forum that will walk you through problems. There are all sorts of problems that can occur. Old sound cards will need buffers, you'll have to have a recent Direct X loaded, etc.
Hope some of this will help. |
mtvic
Posted: Fri Dec 30, 2005 7:17 pm Post subject:
Thank you
Iwill certainly try your suggestion.
Iam preparing to set it up now.
Fingers crossed.
Sonically
mtv _________________ "I'm the transmitter' I give information."
mtvic
Posted: Fri Dec 30, 2005 7:41 pm Post subject:
Danke
everyone
It's alive
please listen in at
GMT
Jan 1 02:00 - 03:00
EST
21:00 - 22:00 (Dec 31) Mike Victor Philadelphia
Iwill be jamming eclectic improv with DJRock.
my good friend for many years .
Sonically
mtvic Last edited by mtvic on Fri Dec 30, 2005 7:45 pm; edited 1 time in total |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Fri Dec 30, 2005 7:42 pm Post subject:
Great, Mike. Glad to hear you got it working. _________________ --Howard
my music and other stuff |
deknow
Posted: Fri Dec 30, 2005 8:55 pm Post subject:
...glad you got it worked out, we will be tuning in from here (i think about a dozen people are coming over).
deknow |
Audio files: 107
seraph
Editor
Joined: Jun 21, 2003 Posts: 12010 Location: Firenze, Italy
Audio files: 31
Posted: Sat Dec 31, 2005 1:23 am Post subject:
I tuned in listening to noodles galore  _________________ homepage - blog - forum - youtube
| Quote: | | Politics is the entertainment division of the military industrial complex - Frank Zappa |
frater v.i.o.
Joined: Dec 19, 2005 Posts: 24 Location: Germany,Cologne
Posted: Sat Dec 31, 2005 4:00 am Post subject:
just tuned in
it takes very long before the schedule url will show up(at least with firefox).
guten rutsch.  _________________ ...it lives again. |
jono
Posted: Sat Dec 31, 2005 4:32 am Post subject:
Noodles Subject description: NYE |
Streaming his fine with the Noodles. Very good
I hope everything goes smoothly and we all get a Happy New Year's Eve Party
Happy New Year |
Mohoyoho
Audio files: 150
Posted: Sat Dec 31, 2005 10:55 am Post subject:
I'm having problems with the schedule page too, and also with the main site, takes for ever to load and quite often doesn't make it. Hopefully it'll all be sorted for later  _________________ Jez
Audio files: 150
Posted: Sat Dec 31, 2005 6:42 pm Post subject:
Well I had fun. Didn't go exactly to 'plan', but went better than the practice run
Happy New year to all _________________ Jez
jono
Posted: Sat Dec 31, 2005 7:22 pm Post subject:
Many Thanks |
Thank you Mosc for this special evening this was a great job.
And thank you to All for the great Gigs and Noodles Streaming.
Thanks.
Happy New Year
Jono |
Audio files: 150
Posted: Sat Dec 31, 2005 10:12 pm Post subject:
Well, I stayed up much later than I should to catch the sets by Antimon, Mike Victor, Deknow and Mosc and enjoyed them all.
When's the next one? _________________ Jez
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Sat Dec 31, 2005 10:15 pm Post subject:
hey this is fun ....
just heard howard's [i presume] New years greeting and shout-outs
thing is, on my end the level is really really low
anyone else? _________________ Spiral Recordings |
paul e.
Posted: Sat Dec 31, 2005 10:31 pm Post subject:
to clarify
the level on the audio portions is good
however, when howard got on the mic, the level was very low
anyhow..great stuff ! good work _________________ Spiral Recordings |
