modules(lfo's or what ever)
Page 1 of 1 [3 Posts]
rubendelacosta
PostPosted: Fri Jan 06, 2006 10:20 pm    Post subject: modules(lfo's or what ever) Reply with quote  Mark this post and the followings unread
i'm thinking about building a module...but i'm not quite shure wich one.
I think i like the lfo's...but i'm new to synth(etc...)building...so..any one knows a easy lfo(or any module) with pcb if it's possible?
thank you.
ruben
Audio files: 51
PostPosted: Sat Jan 07, 2006 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd start with either a VCO or a VCF.
They are the two most fundamental modules IMHO.
An LFO is normally used to modulate another module which has a CV input, so if you build it by itself it won't do much until you have, for example, a VCO.
Check the MFOS site, Ray has a number of module projects there. PCB layouts as well.
Or just type DIY Synth Module into google and see where it leads you.
See ya,
Andrew
We would lose our friends.
So,.........
Pehr
PostPosted: Sat Jan 07, 2006 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I would start with a VCO, ADSR (or AR) and a VCA, so that you can plug in some CVs and gates from a keyboard or sequencer. It's not much but it is the base of a synth. Add that VCF and LFO later... that's what I would have done... Rolling Eyes
