X-Fade Bug (G2, OS 1.32)
Page 1 of 1 [5 Posts]
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Fri Jul 01, 2005 2:13 pm    Post subject: X-Fade Bug (G2, OS 1.32) Reply with quote  Mark this post and the followings unread
A simple bug I've suspected for a longtime: The crossfade module is slightly off mark. Meaning: if you turn the X-Fader hard left or hard right, the outputted signal isn't a 100% equivalent of the respective input signal.
Even if you patch the same signal into both inputs and wiggle the X-Fade control (In linear mode).
XFade-Bug 040705.pch2
 Filename:  XFade-Bug 040705.pch2
 Filesize:  1.21 KB
 Downloaded:  681 Time(s)
beer
Tac_Evaworcim
PostPosted: Tue Jan 17, 2006 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Verified
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Fri Dec 01, 2006 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I suppose this is the same bug...
I'm trying to crossfade between 2 different oscillators and I found that when you turn the knob to the left there is always signal coming from the right input, so basically it doesn't work as expected.
Should't be very difficult to fix!
crossfade bug.pch2
crossfade bug
 Filename:  crossfade bug.pch2
 Filesize:  1.29 KB
 Downloaded:  610 Time(s)
Albert
Audio files: 116
G2 patch files: 317
PostPosted: Fri Dec 01, 2006 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe the wheel doesn't go down to zero ? As I tried to reproduce this with the morph taken out and failed - erm which means the cross fade does fade to silence for me.
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Fri Dec 01, 2006 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Damn! You're right Jan, it does work now!
I swear that when I saved this patch I could hear some saw mixed with the sinewave. This patch was part of a much bigger one I'm working on, so I isolated the basic modules to show the bug, and it was happening.
No wonder what could have happened before Question, and I'm not drunk today!
Well I'm happier now, one bug less Smile
Maybe it's a strange bug of the editor. I usually keep it always opened even when I put the computer into sleep mode (many times in a day).
Sorry for the false alarm
Albert
