| Which sounds better? |
| Take 1 sounds better |
37% |
[ 6 ] |
| They sound the same to me |
62% |
[ 10 ] |
| Take 2 sounds better |
0% |
[ 0 ] |
| Total Votes : 16 |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Wed Jan 25, 2006 8:14 am Post subject:
Does 1.4 sound different than 1.32? Subject description: A semi-objejctive test |
Just as a curiosity, I loaded 1.32 and played a phase shifter patch that G2IAN posted some time ago. See this topic: http://electro-music.com/forum/topic-8071.html and this one: http://electro-music.com/forum/topic-9712.html
Ian remembers that the aliasing sounded worse on 1.32 but he wasn't certain. I loaded both versions of the OS, 1.32 and 1.40 and played the same patch (taken from the first link) with exactly the same volume settings and no other parameter changes. I recorded what I played in a MIDI file and played both OS versions from that MIDI file, so this is a pretty good A/B comparison. I kept things short to save bandwidth. As it is, these are over 7 MB each. I played mostly high notes because that's where the aliasing is most noticable.
Here are two wave files. I won't identify which file is associated from which release for obvious reasons. I'm posting a poll just to see what people think. After a while, I'll identify which version was which. I will say that this isn't a trick - I wouldn't play games posting the same version or something like that.
Of course, this is only one example. If someoine has a different patch that the feel better demonstrates a change in sound character or quality, please let us know.
| Description: |
| Phase shifter test - take 2 |
 Download |
| Filename: |
phase-shifter-take2.wav |
| Filesize: |
7.21 MB |
| Downloaded: |
744 Time(s) |
| Description: |
| Phase shifter test - take 1 |
 Download |
| Filename: |
phase-shifter-take1.wav |
| Filesize: |
7.2 MB |
| Downloaded: |
759 Time(s) |
Posted: Wed Jan 25, 2006 8:17 am Post subject:
Did you try to study waveforms, noise and/or whatever? I would like to see hard data on this. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Audio files: 107
Posted: Wed Jan 25, 2006 8:20 am Post subject:
The files are the data. People can study them as they wish and report their findings here. I prefer to trust my ears, but I'm open to any other methods. _________________ --Howard
my music and other stuff |
Fozzie
Joined: Jun 04, 2004 Posts: 873 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Wed Jan 25, 2006 9:12 am Post subject:
| Interesting test. Looking at the graphic image of the waveforms, I'd say there are diffenences. At the start of the signals, one waveform (blown up totally) shows more evenly distributed amplitude steps than the other. But in sound.... it's rather hard. I say take 1 is 1.40, as it seems to have more bass... well....that's my guess. |
Chet
Joined: Nov 19, 2004 Posts: 226 Location: Lititz,PA,USA
G2 patch files: 35
Posted: Wed Jan 25, 2006 10:40 am Post subject:
| A blind listening test is a great idea. I don't have the download bandwidth until tomorrow, but I'll give them both a listen then. |
jksuperstar
G2 patch files: 18
Posted: Wed Jan 25, 2006 10:43 am Post subject:
My Opinion: Don't read if you haven't listened & voted yet.
*&YnklnaIThink#2HasMoreAliasingAnd#1IsHasMuchLessljknsadcnasdcsandcpjnsd |
Joined: Apr 01, 2004 Posts: 2516 Location: Auckland, New Zealand
G2 patch files: 584
Posted: Wed Jan 25, 2006 12:53 pm Post subject:
| I don't hear a significant difference between the two files. What I recall was a pronounced 'grit' which is not present in these samples. Can't dispute the facts however. Apologies to all for the misinformation. |
frater v.i.o.
Joined: Dec 19, 2005 Posts: 24 Location: Germany,Cologne
Posted: Wed Jan 25, 2006 1:36 pm Post subject:
haven't done the test yet but just curious...if there is some enhancemend with 1.4 is it possible to do a "rollback" to 1.32?
if a machine is uptaded there might be some things not reversable?!?
anyway.doin' the test now...
ok i made my vote.to keep it blind i stay silent and wait for results.
oh and btw, it was not easy to decide if ver. 1 or 2 sounds better because it is also a matter of taste. |
cebec
G2 patch files: 31
Posted: Wed Jan 25, 2006 1:49 pm Post subject:
| frater v.i.o. wrote: | haven't done the test yet but just curious...if there is some enhancemend with 1.4 is it possible to do a "rollback" to 1.32?
this is a possibility raised in another thread. i guess the only way we'll know is if someone who hasn't updated to 1.32 could participate in the discussion. |
Audio files: 107
Posted: Wed Jan 25, 2006 2:17 pm Post subject:
Anyone can run the synth updated program from any previous version and it will install the older version for you. If this is incorrect, then I'll remove this test because that's what I did. _________________ --Howard
Tim Kleinert
Joined: Mar 12, 2004 Posts: 990 Location: Zürich, Switzerland
Audio files: 6
G2 patch files: 201
Posted: Wed Jan 25, 2006 2:19 pm Post subject:
I have 2 G2Xs. I haven't had time to update yet. I might update one to 1.4 and not the other and play them side by side. _________________
Fozzie
G2 patch files: 49
Posted: Wed Jan 25, 2006 2:22 pm Post subject:
That would be great, Tim, to really kill any myths (although I still believe)  |
Fozzie
G2 patch files: 49
Posted: Wed Jan 25, 2006 2:48 pm Post subject:
This is a difference in waveform I'd say (from the first few notes; I selected a part where the pitch changes to check correct alignment)
[edit] added more pics. All zoom levels are equal, even though the scales don't seem identical (caused by scrolling the tracks into the right part of the screen).
| Description: |
| waveform of the left channels from the blind test v1.4 vs v1.32 |
| Filesize: |
22.18 KB |
| Viewed: |
7643 Time(s) |
| Description: |
| And a little further down the line |
| Filesize: |
27.71 KB |
| Viewed: |
7641 Time(s) |
| Description: |
| I guess I made my point by now ;) |
| Filesize: |
165.68 KB |
| Viewed: |
7634 Time(s) |
Audio files: 107
Posted: Wed Jan 25, 2006 3:16 pm Post subject:
In this particular patch, the LFOs and the oscillators aren't synced to the note onsets, so it's probably normal to expect the waveforms to look different even. Sometimes, looking at waveforms doesn't help all that much. _________________ --Howard
Fozzie
G2 patch files: 49
Posted: Wed Jan 25, 2006 3:24 pm Post subject:
Ahh, good remark Mosc. I haven't actually looked at the patch itself, but I could/should have thought of that myself
Very OT remark: just downloaded Audacity to look at the waves, and it's a very (!) nice program. Cool spectrum analysis tools & lots & lots more... |
Fozzie
G2 patch files: 49
Posted: Wed Jan 25, 2006 3:29 pm Post subject:
The fact that lfo's and osc's aren't synced do make the comparison semi-objective, however. I have focussed my listening on some specific parts of the demo, where I could hear clear differences. These could also have been caused by the free running oscillators  |
Joined: Apr 03, 2004 Posts: 19583 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Wed Jan 25, 2006 3:35 pm Post subject:
For the 2nd part of the test the two files should be swapped, the topmost is listened to considerably more than the bottom most. The topmost gets more votes for "better sounding" as well. The test is obviously biased now :-) _________________ Jan |
Posted: Wed Jan 25, 2006 3:40 pm Post subject:
Well.. sometimes... but is this a contest? Which is the better sounding? that doesn´t make any sense. What we would want to know is: Is there an audible difference between these OS versions? If so, what did they do and how and "why". Then we would want to do tests in order to figure how this difference really sounds like.
Dunno.. perhaps I am anal about these matters.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
gee
Joined: Jan 25, 2006 Posts: 1 Location: The Netherlands
Afro88
Joined: Jun 20, 2004 Posts: 701 Location: Brisbane, Australia
Audio files: 12
G2 patch files: 79
Posted: Wed Jan 25, 2006 6:40 pm Post subject:
I think they both sound fine, and I don't think there's any way I can tell the difference between the two. The aliasing is minimal (because of the filtering) in both until you hit that top note... And I'm one of the "believers" in the 1.40 sounding better myth!
A much better test in my opinion would be Tim turning the filter off and playing some long notes on each G2x, then piecing together the wav file the way gee has - 2 sustained notes, one for each OS, then octave up and repeat, keeping the order the same each time. |
Audio files: 116
G2 patch files: 317
Posted: Wed Jan 25, 2006 7:04 pm Post subject:
deknow
Posted: Wed Jan 25, 2006 8:12 pm Post subject:
perhaps some of us should form a cult based on the notion that we like the 1.32 sound quality significantly better, and are willing to give up patch mutation/adjusting in order to be able to use the 1.32 os.
from time to time, we can gripe about that clavia won't listen to our requests to maintain 2 paralell operating systems...one with the "new, better sound" and one without, so that we can all benefit from the new software, and not feel left unsupported and betrayed (we did buy the machine for the "old sound", after all).
deknow  |
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Wed Jan 25, 2006 8:45 pm Post subject:
i perceive take 1 to have a slightly brighter sound..a bit more presence than take 2...
take 2 has a slighter darker tone that some may find more preferrable, as i did, so it's hard to say which sounded 'better' |
varice
Joined: Dec 29, 2004 Posts: 626 Location: Northeastern shore of Toledo Bend
G2 patch files: 46
Posted: Wed Jan 25, 2006 10:11 pm Post subject:
Howard,
Thanks for the time and effort to put this test together. I have listened to both takes and I must say that there is a horrible amount of aliasing noise in both. If there were some DSP code tweaks to OS 1.40, the tweaks did not do much to reduce aliasing, at least for the aliasing generated by this particular patch. I think that I hear a slight difference between the takes, but this may only be because I already know that the two were generated by different OS versions. So, based on the sound of these two takes and better judgment, my vote will have to be that the two OS versions sound the same.
About 24 hours ago, I thought about rolling my G2X back to 1.32 to try a similar test, but decided to try a quick test first. If I could hear a significant difference between the 1.32 Demo Software and the 1.40 loaded on the G2X, then I would go to the trouble of switching OS versions on the G2X for more detailed testing. After comparing the sound of several patches (including the sawAnimate.pch2 used in your test), I decided that I could not hear a significant difference between the two!
All of this leads me to believe that there were probably no DSP code tweaks to OS 1.40 specifically for improving the sound of the G2. _________________ varice |
varice
G2 patch files: 46
Posted: Wed Jan 25, 2006 11:28 pm Post subject:
| Fozzie wrote: | The fact that lfo's and osc's aren't synced do make the comparison semi-objective, however. I have focussed my listening on some specific parts of the demo, where I could hear clear differences. These could also have been caused by the free running oscillators  |
The takes do not sound exactly the same because of the free running oscillators and LFOs, but I do not think that exact duplication of sound is what this test is about. The test is about percieved sound quality differences between the takes generated by the two OS versions. The overall sound quality for the duration of the takes should not be affected much by the difference in phase of the oscillators during the recording of the two takes.
Just my opinion - what makes this test of which take sounds better very difficult is the fact that both takes sound bad because of the horrible aliasing! _________________ varice |
