Posted: Sun Jan 18, 2004 11:25 am Post subject:
mLAN audio and midi interface from Yamaha |
mLAN at last..
The i88X is an mLAN-based Audio and MIDI interface which features two mic and six line inputs that deliver audio to the unit's 24-bit96kHz A/D converters. Built-in ADAT Light Pipe compatibility and SPDIF I/O allows for 18 simultaneous inputs and outputs. The i88X can be used as a stand-alone 18-channel computer I/O, or as an expansion device in an mLAN network. Because the i88X is mLAN compatible, users get the added benefits of integration with over 40 mLAN licensee company products.
mLAN is Yamaha´s name for its embedding protocol for audio and midi over firewire. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
seraph
Editor
Joined: Jun 21, 2003 Posts: 12010 Location: Firenze, Italy
Audio files: 31
Posted: Sun Jan 18, 2004 11:37 am Post subject:
Are you sure that mLan stuff is compatible with equipment made by manufacturers other than Yamaha  _________________ homepage - blog - forum - youtube
| Quote: | | Politics is the entertainment division of the military industrial complex - Frank Zappa |
Posted: Sun Jan 18, 2004 11:46 am Post subject:
Well.. in order to use the mLAN features on a device to device basis, you would need mLAN gear. On the other hand, just install the software drivers on your mac or PC and then you are ready to B & B. This is really just a firewire device.. it is the embedding protocol that is a bit "special" and what yamaha calls mLAN. well.. mLAN depends on a lot of features in the firwire protocol too. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Mon Jan 19, 2004 8:26 am Post subject:
Right. As I understand it, Firewire is just a serial I/O connection, like USB, or RS232. There is no standard way to send audio or MIDI over the interface. So, you need a driver for every device you have. You can't just hook up a MOTU and a KYMA on a Firewire interface and expect them to talk to each other. If they were MLAN devices, they could.
If the MLAN technology takes off, it could be very useful. |
Posted: Mon Jan 19, 2004 8:43 am Post subject:
That is correct, Howard. So mLAN is a good thing. You can check out the mLAN faq at the tech pages over at Yamaha. Their implementation seems very solid. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
