hyperstationjr
Joined: Jun 12, 2005 Posts: 111 Location: New Jersey/New York
G2 patch files: 24
Posted: Fri Feb 10, 2006 4:57 pm Post subject:
Sequence Glitcher... Subject description: 6 channels of both Audio and Midi glitch... |
Just run the audio and Midi thru this patch...
I have't acctually tested it, because I only have an engine, and this is too much for the poor little guy...
Anyone have any ideas? Fixes? I'd really like some input on this one, I think it could be an awsome performance patch...
Description: |
Download |
Filename: |
Seq Glitcher.pch2 |
Filesize: |
6.93 KB |
Downloaded: |
1339 Time(s) |
_________________ Studio:
Blokas MidiHub, Clavia Nord Modular G2 Engine, Elektron Analog Four Mk2, Elektron Digitone, Elektron Machinedrum UW+ Mk2, Elektron Octatrack Mk2
For Sale/Trade:
Alesis Microverb 4, Make Noise 0-Coast, Monome Norns Fates clone, Panasonic RQ-705 Reel-to-reel, Roland Alpha Juno1, Yamaha TG55 |
Audio files: 278
Posted: Fri Feb 10, 2006 5:35 pm Post subject:
It is all a bit confusing with DSP percentages and expansion boards, but the engine does have the same capabilities, DSP wise, as any other G2. This patch has a patch load over 100%, and that means it will not run on whatever G2 you use.
Ah well the good news is you don't have to be disapointed about "only" having an engine :)
Anyway, no escape, you'll have to make it simpler to get it to work, or otherwise split the patch maybe over multiple slots, or have a part of it in the FX area maybe.
Here are some possibilities I see to make it cheaper DSP wise :
- Replace the LFO's by cheaper LFO's, that is LFO C
- Replace the analog delays by the SR8 module (DlyShiftReg) that you clock from an LFO running at a few Hz. Or set shorter delay times.
- Leave out the random modules, that will not change the basic idea too much I guess - you could always set the LFO's to a random waveform (for LFO C that is).
Using these you'll be able to get it under 100% I think. _________________ Jan
hyperstationjr
G2 patch files: 24
Joined: Jan 31, 2003 Posts: 18197 Location: Durham, NC
Audio files: 212
Posted: Fri Feb 10, 2006 9:55 pm Post subject:
Interesting patch. If you make upgrades to the patch, it might be best to replace the attachement with the newest version. Then there are less versions running around to confues things. You can edit any post (assuming you are the author, of course). _________________ --Howard
my music and other stuff |
hyperstationjr
G2 patch files: 24
Posted: Fri Feb 10, 2006 10:26 pm Post subject:
Yep, kind of learned that in a funny way. I'll do that from now on... _________________ Studio:
For Sale/Trade:
